Hi Mald0n,
Just a bit back to previous, this is my case, you did it.
So yah, I'm fine with Big Sur right now, not Monterey, (Monterey can be installed with no wifi, bt)
I use the same EFI that used to successfully install for BigSur and Monterey(no wf, bt), could you please somehow make it works for Ventura as well?
Thank you very much,
Steve
EFI.zip Send me Steves-Mac-Pro.zip
idk about this problem
we tried many tim es and problem stay there
