Is there a know problem with the WD Blue SN570?
  • motherboard: Gigabyte GA-Z170X-Gaming 7
  • CPU: i7 6700K Skylake
  • Memory: 16GB Crucial Ballistix Sport LT 2400 MHz DDR4 DRAM
  • Graphics: Sapphire RX6600
  • SSD: WD Blue SN570 2TB
    I've had many issues getting this new install of Monterey to work properly. I've had some help from MaLd0nWith his help, I finally got it to boot from my new NVME drive. It worked for a week or so but I thought boot times were slower than my previous Sierra install on an old SATA SSD. Now the Monterey install is back to freezing midway through the GUI boot screen. Even though the "-v" boot arg is there I'm not getting verbose.
    I decided to try installing Monterey on the old SATA SSD and it was so smooth quick and easy. Boot times are super quick. I can see the NVME drive and access it through this, but nothing seems to change with being able to boot with that drive. I can't even erase and reinstall. It always says that drive is in use even though I didn't boot from it. I tried using terminal to reformat and it won't even let me do that. Maybe I'm using the wrong commands I'm not sure. Is there a know problem with the WD Blue SN570?
use mp600 corsair and wd 750 black
23 minutes ago, Aaron Whitmoyer said:
So the WD Blue is crap?
i never use it. need check
