#help me pleaae
Hello. Can you help me with this problem.  thanks
All in one Desktop
Motherboard Name: Acidanthera Mac-A61BADE1FDAD7B05
CPU Type:  HexaCore Intel Core i7-10750H, 3700 MHz (37 x 100)
GPU:  Intel(R) UHD Graphics  (1 GB)
RAM : 32GB DDR4 3200
SSD:  WDC  WDS500G2B0A-00SM50  (500 GB, SATA-III)
OS:  Ventura
image source: Olarila
Opencore v0.8.5
Not working
WIFI:   "Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC"
Audio:  "Realtek ALC662 @ Intel Kaby Point PCH - High Definition Audio Controller (Audio, Voice, Speech)"
*im using AppleALC.kext and alcid=11 in boot args
Blinking display
*please see the video
Camera: USB\VID_0C45&PID_636D&REV_0100&MI_00
EFI Link: https://www.mediafire.com/file/co1fgmdh3tdrqhm/EFI.zip/file
Screenshot
Video for blinking display
use correct efi folder for ur after installation
-NoteBook CoffeeLake Plus and CometLake Download HERE
Olá Maldon, bom dia meu amigo.
Você sabe me informar como resolvo este erro no OPENCORE? A tela trava e não inicia mais, aconteceu depois de atualizar para 0.8.5.
SMCRTC: STOP
Imagem: https://i.ibb.co/8mynRWn/erroSMC.jpg
Obrigado
Desktop (macOS Monterey 12.5.1) - MB: Gigabyte H310M H 2.0 | CPU : i5 9400F | RAM : 16 GB Crucial Ballistix Sport LT DDR4 2666 | GPU :  AMD RX 580  Sapphire NITRO+ 4GB | SSD : WD Verde 480 GB
after i place this EFI, should i generate the SMBIOS? and do i need to patch the acpi?
