I have a PC on which I have installed macOS Ventura and Windows 11 on 2 separate SSDs. When I turn on the PC and start macOS Ventura, the Bluetooth does not work! (activating it in the Settings, He deactivates immediately). On the contrary, if I turn on the PC and start Windows 11, I let all the services load, restart and this time, in the Opencore menu I select macOS Ventura, the Bluetooth works great !!! I hope you understand the problem. To have the Bluetooth working, I have to start Windows and then restart and finally select Ventura.
what bt u have
we dont have crystal ball. u need post ur full hardware specs
Asus VivoMini UN65U
DualCore Intel Core i3-7100U, 2400 MHz (24 x 100)
Intel Sunrise Point-LP, Intel Kaby Lake-U
Intel HD Graphics 620
Intel Kaby Lake HDMI @ Intel Sunrise Point-LP PCH - High Definition Audio Controller [C1]
Intel(R) Dual Band Wireless-AC 7265
Intel(R) Wireless Bluetooth(R)
I deleted my kext and copied the 4 kext you provided me. I did nvram reset. After the reboot the Bluetooth worked. I shut down the PC completely. I turned on the PC and started Ventura first and the Bluetooth works great without necessarily starting Windows !!!!!! At the very least I want to make a donation, I already tried yesterday but, it led me to pay with Paypal! How can I donate without Paypal? Good work thanks
Here
Support Olarila Vanilla Hackintosh by making a donation HERE
About Premium Users you can check HERE
Unfortunately my bluetooth stopped working! The button in the system settings activates, but the icon in the control center does not light up. The wifi works well! (macOS Ventura beta 13.5 /22G5027e). On windows 11 bluetooth works, when I reboot to Ventura, it doesn't turn on at all
