EFI Folder for Hp 14s-dq2021ns (NOT SURE if I deserve it ^^')
I made my Ventura haxckintosh in my HP laptop Installed on a SSD external USB Kingston disk with the intention of restoring it to the internal NVME but I'm not winning in my battle of macOS to recognize it, also with Wifi. Also, as I say, I'm not sure if I have the "right" to ask for the complet EFI folder, or if I should donate a superior amount (I WOULD DO IT SO GLAD). Could you please help me in having clear what I may ask you? I wouldn't like to be disturbing. I'm attaching my Send ME zip and some screenshots of my system.
For finishing, would it be possible to run my laptop from Clover with Ventura working good permanently and my Zorin OS?? In case not, could I with OC? Believe me that I've been struggling hard during months and I would really donate a reasonable amount with any problem. Thanks for your project.
Send me MacBook-MacBook-Pro-de-Marc.zip Captura de pantalla de 2022-10-06 04-5.zip
This igpu 11gen don't have support under macos
