Here is my RunMe zip:https://easyupload.io/p1h3d5
Installation of Monterey successful. I've copied the EFI to the SSD after complete install.
Working: WIFI, internal sound and HDMI sound, Saphire Rx6600
Not Working: Bluetooth. AppleID-imessage-icloud(not sure yet as I want to make sure it boots first). It still won't boot without the USB stick after copying EFI to SSD. Freezes on: PCI (Build 14:23:33 Aug 10,2022),Flags 0xc 3080
clover no, just need paste
oc yes, need add entry
Ok. I patched OC in OC configurator. Tried to reboot without USB stick and it freezes on:
In memory panic stackshot succeeded **Bytes Traced 4891 (Uncompressed 12784)**
Attempting system restart
MACH Reboot
use opencore or clover
sendme extract both folders. what happens? u used one in ssd and one in usb stick?
EFI.zip
Well I tried that EFI. Once without the DSDT (applekeystore failed), and once with it (hangs on txflush 1170). Neither would boot from SSD without the USB stick. I then tried it with the USB stick and couldn’t get it to boot at all (txflush 1170 and IOCONSOLEUSERS: gIO screenlockstate). I’m not sure what to do anymore.
is a IGPU problem
IGPU is enabled? u have monitor connected on IGPU?
send me PM on telegram
i need check some things. is not common errors
