Hi there
i wonder if its possible to install Monterey on my Zephyrus M16 GU603HM -211.ZM16
my system boot and then stop on apple logo with your efi https://olarila.com/files/OPENCORE.MOD1/EFI.Opencore.NoteBook.TigerLake.MOD.zip
is my second try with hackintosh and i don't know much
The only place i found info about this laptop is your page
Please, any help, info or pointing reference is important for me
Thank you in advance
On 9/28/2022 at 2:11 PM, ykardis said:
Thank you for your quick responce
but , no luck for meerror.zip
it stop there, i dont know why
Y
Hello, I have the same laptop could you find any solution?
