Hi,
I've already had Olariala help on DSDT configuration in the past, under VDV login (not working any longer).
I've been able to install and run Catalina, taking inspiration and copying from others.
PM is working, USB, etc. working.
I would need your help to fix followings:
1) Not able to Update to Monterey (when I update I get error enclosed in picture). Looked on web but not able to find something similar.
2) Sleep not working (sleep but wake after few seconds).
3) Only able to install as legacy. I'm not able to have UEFI.
Can you help me?
IMG_6659.zip
Here my EFI folder.
EFI.zip
Edited by Diego Vedovato
Hey
What ur hardware
Dell T5600 - Motherboard from DELL
2 x Xeon 2690V1 (Sandy Bridge) + 32Gb
RX590 Nitro +
External Board PCI-E for USB3 working OOB
External Board SATA working OOBDSDT.aml.zip
This is the DSDT you created for me:
Only difference is Video Card (was 980GTX, now ATI RX590)
debug_23082-2 2.zip
I don't know if this can help (basic hardware still the same), coming from High Sierra.
after catalina(i think) dual socket have several problems and don't work good
Thanks for reply.
I know the HP Z820 (which extremely similar) is working fine on Monterey. Support on this machine is quite nice from several users. EFI folder are ready.
I know those machines sleep not working (since High Sierra).
Is there any improvement you can do on EFI folder I updated?
Many thanks in advance.
this chipset is x99 or x79?
