Aboud DSDT:
1) I extracted my DSDT from windows and saved in bin format
2) I copied it to my osx
3) now I decompiled then compiled by Chameleon Wizard and it fixed all errors ( I think there is no patch for me Dell cps L502x)
4) when I read about DSDT patched I don't get where to put the DTGP method
For sound I have ALC665 and I have the codecs dump from linux now what should I do?!
About display port HDMI how to enable that using Intel HD 3000 though the sound is my priority for now.
about the dsdt.. only extract and no patch applied
is better u leave it where it belongs
and the boot loader apply the minimum patch to boot
about sound..
mac os x 2 solutions
applehda
http://Olarila.com/forum/viewtopic.php?f=28&t=2676
voodoohda
http://Olarila.com/forum/viewtopic.php?f=28&t=454
You said leave dsdt but in the fix for the audio you linked there is dsdt editing needed?! Also I don't have a bootloaderon they don't work for me and if I used any of them either osx wont start anymore or it just do nothing and still cant boot except from installation usb so I don't know what to do when I edit the dsdt where to put.
what i say is only extract dsdt and no patch... u leave it there where u extracted..
about the others questions.. my only advice to u.. is to read about what are u trying to do
mac os x is for mac and developed exclusively for mac
hack mac os x is 99% of reading, googling, persistency and 1% of luck u have compatible hardware
