Hi, i have tested couple of EFIs but i cant get it to work. The longest part was successfull boot of Monterey and install on nvme but @ 12min before install end just crash and restart...
Here are the specs, please advise:
OptiPlex 3050
Intel Core i3-7100 (DC/3MB/4T/3.9GHz/65W)
2 x 8GB DDR4
Intel HD 630 Graphics
Intel® B250 Chipset
Realtek ALC3234
Realtek RTL8111HSD-CG Gigabit Ethernet LAN 10/100/1000
1x HDD WD 500GB
1x M.2 PCIe SSD
Use essa pasta efi
https://easyupload.io/2aobxh
Hi Mald0n,
how are you, hope u`re fine...
I`m having problems with Hackintosh, cant get HDMI working, whatever i try...
Can you assist? DP is doing fine picture is awesome, but HDMi no image black screen pink screen... all rainbow colors...
The computer is the same as above allready mentioned...
Here is link from Run Me app
https://www43.zippyshare.com/v/HwAzwl60/file.html
Is it ok to donate $10?
Edited by Sanitarac
misspelled
On 9/17/2022 at 2:49 AM, MaLd0n said:
Use essa pasta efi
Morning MaLd0n, Can you update the link it's not working anymore. I have the same exact CPU and it's not supported by hackintosh fully since I can't get the graphics to work if there is any solution kindly reply back.
