Sorry for my English.
From few months i'm trying to install macos on my hp elitebook 8730w but not succeed.
Can some one help me to provide efi folder for below configuration.
Processor - Intel® Core™2 Duo Processor P8400 2.26 ghz penryn
RAM - 4 GB
Graphics - ati radeon hd 3670
Audio - SoundMAX integrated digital HD audio
Edited by Kayu V
Changes
lga 775
Thanks MaLd0n for prompt response.
I have already tried but not worked with lga 775
My Sockets Supported is PGA478, BGA479
please help me to find efi for above socket details.
thanks in advance
Edited by Kayu V
use lga 775 efi clover folder and u need install in esp with boot0ss
Ok.
efi clover folder and u need install in esp with boot0ss - i am new in this things could you please share guide link or step by step process.
Thanks in advance.
Edited by Kayu V
is not olarila efi folder
have a bunch of bad things in ur efi
Yes sorry.
Now i have used lga 775 efi folder and appearing "boot0ss: error" (image attached). You have mentioned boot0ss related in trail but i dont know how to do. Please help me.
I am using hp elitebook 8730w with window 7 gpt partition.
IMG_20220928_224742.rar
Edited by Kayu V
Yes sorry.
Hi, MaLd0n
I have used lga 775 efi folder but appearing "boot0ss: error" (image attached) at the time of installing high sierra. Please help me.
RAM - 4 GB
Edited by Kayu V
many times i dont use legacy mobo
need check if something is change
I have tried with  UEFI.
So what details you required to solve this issue.
Is it need to change anything from config.plist for boot0ss: error?
Edited by Kayu V
can you please help me to provide working clover to atleast boot and install the setup.
*LGA 775 clover not working for me. Macos install option disappeared from clover install screen.
BIOS: F.20 (with AHCI support it would seem)
CPU: Intel Penryn C2D P8400 FSB-1066 @2.26GHz
RAM: 4GB DDR2-800 (PC2-6400)
dGPU: ATI Mobility Radeon HD 3670 2GB (PCI id 1002:9593)
Display: 1680x1050 built-in LCD
Audio: Analog Devices AD1984A Codec
IO Controller: Intel ICH9-M
USB: USB2.0 ports
Disk: 160GB Hitachi HTS543216L9A300 5400rpm SATA-II HDD
LAN: Intel 82567LM Gigabit Ethernet
Wireless: Intel Wifi Link 5300 AGN
TouchPad: Synaptics
SD card reader: Ricoh R/RL/5C476(II) (PCie)
Optical drive: TSSTcorp TS-L633M CD/DVD writer
Edited by Kayu V
USB: USB2.0 ports
TouchPad: Synaptics
Sorry for my English,
    I have a 8730w too, and installed macos 10.13.6 on it. https://www.insanelymac.com/forum/topic/274941-guide-–-hp8530p8530w-–-mavericks-1091/?do=findComment&comment=2730458
   You dGPU card  is not fit, if you want to go on, I advance you change it .
