Hi, If you could tell me how to disable my Micron 2200 SSD For Hackintosh i would be really happy ?, because i keep getting a Kernel Panic in boot?NVMeFix.kext does not work
I have a WD Hard drive so i Do have a Drive to install MacOS Monterey on
My Specs:
  • Laptop - Acer Nitro 5 A517-51
  • CPU - Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
  • DGPU - NVIDIA GeForce RTX 2060
  • IGPU - Intel(R) UHD Graphics 630
  • ChipSet - Intel 300 Series Chipset Family
  • Keyboard- Standard PS/2 Keyboard Audio Codec - Realtek ALC255 @ Intel Cannon Point PCH - cAVS (Audio, Voice, Speech) [B0] PCI Wifi - Intel Wi-Fi 6 AX200 160MHz Wireless Network Adapter PCI
  • SSD - Micron 2200
  • Hard Drive - WDC
Using OpenCore
check what PciRoot and inject patch bellow. I'm using this patch to disable my ssd nvme corsai 510 with no good support under macos
Quote
<key>PciRoot(0x0)/Pci(0x1A,0x0)/Pci(0x0,0x0)</key> <---RP25.PXSX
            <dict>
                <key>IOName</key>
                <string>#Olarila</string>
                <key>compatible</key>
                <data>/////w==</data>
                <key>device-id</key>
                <key>name</key>
                <key>revision-id</key>
                <key>subsystem-id</key>
                <key>subsystem-vendor-id</key>
                <key>vendor-id</key>
            </dict>
