Z390 I Aorus Pro Wifi, i5 8500 UHD 630 Crashing/Random Freezing
 I have a running installation of Monterey 12.4 and I have patched my graphics/config file according to the WhateverGreen documents for UHD 630. I am using the EFI folder for Desktop CoffeeLake from here on Olarila. For some reason, the machine is very laggy when I get to the login screen and first login. After 1-2 minutes the lag goes away. Browser's randomly crash with error code "Aw Snap" error code 10 and error code 11. The machine will randomly lockup and freeze as-well. I have my bios settings set according to the installation guide. What is causing this random freezing/crashing? Graphics Acceleration is full supported/working and so is DRM.
  Device Properties: https://ibb.co/8BJw6Yp
  Boot Flags: https://ibb.co/s2brHs8
  EFI with removed Serials: https://easyupload.io/o42lkm
  Hardware:
    i5 8500 UHD 630
    16gb DDR4
    No GPU
    Gigabyte z390 I aorus pro wifi
@MaLd0n
Forgot to mention, I have also removed unnecessary kexts from EFI after install like the guide says
Edited by CycleFire
Add details
got the same issue after the update to Sonoma, can I send my efi here to check if there is anything triggering this issue?
Please and thank you
@MaLd0n
Edited by orbee
Post here
I need full efi folder with one ioreg with ioreg explorer
Use last bios/uefi version
https://easyupload.io/zmbw04
-Bios/UEFI in full default settings(CSM to Disable with AMD GPU - Sata to Ahci - Secure Boot Disable on mobiles)
@MaLd0n thanks for your help, now the login screen is taking really long to appears. THere is a black screen that stay there for 3 minutes before get to the login, is it something related to the boots args?
the cpu is 13600kf, without the IGPU
Edited by orbee
Save one ioreg
Do u reseted nvram? Bios in full default with last version?
Hey! Thanks again, so the bios is the default, and the last version, did the change that you told me about.
https://easyupload.io/egrp8s this is the IoReg
On a positive note, the chrome issue disappeared, now the issues are:
Bluetooth not working anymore, with the original EFI was working
Black screen for 3 minutes before the login screen appears
some of the USBs stopped working
Thanks in advance
Edited by orbee
Ok for some reason now it's working perfectly, booting perfectly and no more error on Chrome!
Thanks @MaLd0n, gonna drop a donation because you always help!
Enjoy!
