I had a perfectly functional Hackintosh, both in Yosemite and Sierra.
I had to move and my boot olaralila USB drive broke, so I made a new one, but there's something missing because now I lost my sound configuration.
Everything was working fine before, but now nothing, sound is ghosted except for my Plantronics USB headset.
So I followed all instructions to reconfigure it, I'm using AppleALC, and boot options alcid=5, because that is the format that supports a basic light blue green pink layout. I read the info.plist file and it shows 5 is the right configuration.
The problem is I'm missing something, because when I open the system report, Intel High Definition Audio, is showing ID 0. and not mapping anything as it used to be before the accident.
I barely remember what I did before to fix it, but it had to do with some tables on boot.
I tried to open config.plist with Clover, but have a permissions error trying to fix it, so I hard coded the alcid=5 on Clover Options, on the Boot Screen.
Any ideas?
Edited by icecold
post ur full hardware specs
Motherboard-  ASROCK H61M-DGS
Radeon HD6870 1Gb
Platform - Micro ATX Form Factor: 8.9-in x 6.8-in, 22.6 cm x 17.3 cm
- Solid Capacitor for CPU power
CPU - Supports 2nd Generation Intel® CoreTM i7 / i5 / i3 in
LGA1155 Package
- Supports Intel® Turbo Boost 2.0 Technology
- Supports K-Series unlocked CPU
- Supports Hyper-Threading Technology (see CAUTION 1)
Chipset - Intel® H61
Memory - Dual Channel DDR3 Memory Technology (see CAUTION 2)
- 2 x DDR3 DIMM slots
- Supports DDR3 1600/1333/1066 non-ECC, un-buffered
memory (DDR3 1600 with Intel® Ivy Bridge CPU,
DDR3 1333 with Intel® Sandy Bridge CPU)
- Max. capacity of system memory: 16GB (see CAUTION 3)
Expansion Slot - 1 x PCI Express 2.0 x16 slot (blue @ x16 mode)
- 1 x PCI Express 2.0 x1 slot
Graphics - Supports Intel® HD Graphics Built-in Visuals: Intel® Quick
Sync Video, Intel® Clear Video HD Technology, Intel® HD
Graphics 2000/3000, Intel® Advanced Vector Extensions
(AVX)
- Pixel Shader 4.1, DirectX 11 with Intel® Ivy Bridge CPU,
DirectX 10.1 with Intel® Sandy Bridge CPU
- Max. shared memory 1759MB (see CAUTION 4)
- Dual VGA Output: support DVI-D and D-Sub ports by
independent display controllers
- Supports DVI with max. resolution up to 1920x1200 @ 60Hz
- Supports D-Sub with max. resolution up to 2048x1536
@ 75Hz
- Supports HDCP function with DVI port
- Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback
with DVI port
Audio - 5.1 CH HD Audio (Realtek ALC662 Audio Codec)
LAN - PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Realtek RTL8111C
- Supports Wake-On-LAN
- Supports PXE
Edited by icecold
if ur hardware dont work on full uefi u need extra procedure for legacy hardware
It was working before but I fixed this long time ago so I can't remember exactly what I did,  but apparently it was done in the USB drive's UEFI. Because otherwise this fresh copy of SIerra I downloaded from your site should work. Where should I look? What directories?
IT supports UEFI >>>
- 32Mb AMI BIOS
- AMI UEFI Legal BIOS with GUI support
- Supports “Plug and Play”
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
- IGPU, DRAM, PCH, CPU PLL, VTT, VCCSA Voltage
Multi-adjustment
