I need some help i've been looking everywhere but no success my hackintosh says at graphics "Display 8mb" no idea how to fix that tried a few EFI's but nothing works. Only my initial EFI from your site works but with no hardware acceleration. My specs are:
CPU: i7 8700
iGPU: UHD 630
GPU: gtx1660ti  (i know it doesn't work on mac)
Motherboard: AsRock b360m
If you can help that would be awesome. Thanks in advance.
u can start with this little patch and change all u need
Quote
            <dict>
                <data>BwCbPg==</data>
                <data>AQAAAA==</data>
            </dict>
I tried typing it and now it doesn't start it says:
OCS: No schema for boot at 0 index, context <root>!
OCS: No schema for Graphics at 1 index, context <root>!
OCS: No schema for Quirks at 2 index, context <root>!
OC: Configuration requires but no vault provided!
I have my previous efi on a flashdrive so i can always start my mac but i still have no hardware acceleration
what should i do?
So i should copy the patch and paste it in clover text mode?
yes
i tried it with the framebuffer and without it and it seems to be fixing one of the lines here:
now it only says:
so this "OCS: No schema for Quirks at 2 index, context <root>!" appears to be fixed when i don't type the framebuffer in graphics
use olarila efi folder and apply ur patches
i'm using your EFI.Opencore.Desktop.CoffeeLake folder with the patch you sent me and this is what i'm getting:
if u have errors above is not folders from Olarila.com
my only folder is from this site olarila.com it's EFI.Opencore.Desktop.CoffeLake from the "EFI FOLDERS" part in the website. Without the patch the OS works but i have no iGPU "Display 8mb" and no hardware acceleration. With the patch i get an error
so no third party stuff only your EFI's
