Help Audio Hp Prodesk 600 G1
Hi, I installed monterey 12.5.1 on my hp prodesk 600 g1, with gt 730 video card, everything works but only the audio I can't get it to work, could someone help me? thank you
inject alcid=3 or alcid=13 for example reboot and check if appear what codec
if no check manufacturer page
nothing to do i can't show my audio, alc 221, it's a hp prodesk 600 g1 i3 gt 730 video card, mountery 12.5.1
can someone help me step by step?
I'll explain my situation, so you see where I'm wrong, I install montery just finished, I copy the Efi folder and put it in the efi of the hard disk, then I install nvidia kepler for the gt 730 and everything works, I have seen from aida64 with windows that I have ALC221 , I have tried in every way but I can not show audio, I do not check anything. working audio from windows and linux.
please help me, maybe explain me the steps to take.
Edited by neonico
