jamesst20 Posted August 26, 2022 Share Posted August 26, 2022 Hi, I have an ASUS-TUF-GAMING-B660M-PLUS-Wi-Fi-D4 and I am unable to get sleep to not instant wake. I have tested someone else EFI and my sleep works with it https://github.com/Xmingbai/ASUS-TUF-GAMING-B660M-PLUS-Wi-Fi-D4-Hackintosh I noticed that EFI uses SSDT-DISABLE-AWAC instead of SSDT-AWAC and I would like to understand what that means, what's the difference and if it could be related to my sleep issue? Thank you Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted August 26, 2022 Administrators Share Posted August 26, 2022 i think is nothing post two files here -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
jamesst20 Posted September 1, 2022 Author Share Posted September 1, 2022 (edited) On 8/26/2022 at 2:42 PM, MaLd0n said: i think is nothing post two files here Sorry for the late reply. Here is the SendMe of my computer having trouble to sleep (Instant Wake): https://file.io/JEeW8rp8dupg and here is an EFI I found where the sleep works out of the box: https://github.com/Xmingbai/ASUS-TUF-GAMING-B660M-PLUS-Wi-Fi-D4-Hackintosh/releases/download/Ver0.8.3/ASUS-TUF-B660M-PLUS-.WIFI.-RX6950XTorRX6650XT-OC083-EFI.zip Not sure what I am doing wrong in mine. Edit: My bad I was missing the GPRW patch in ACPI. <dict> <key>Base</key> <string></string> <key>BaseSkip</key> <integer>0</integer> <key>Comment</key> <string>change Method(GPRW,2,N) to XPRW, pair with SSDT-GPRW.aml</string> <key>Count</key> <integer>0</integer> <key>Enabled</key> <true/> <key>Find</key> <data>R1BSVwI=</data> <key>Limit</key> <integer>0</integer> <key>Mask</key> <data></data> <key>OemTableId</key> <data></data> <key>Replace</key> <data>WFBSVwI=</data> <key>ReplaceMask</key> <data></data> <key>Skip</key> <integer>0</integer> <key>TableLength</key> <integer>0</integer> <key>TableSignature</key> <data></data> </dict> Do you see any improvement that can be done while we're here Edited September 1, 2022 by jamesst20 Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted September 2, 2022 Administrators Share Posted September 2, 2022 use Olarila efi folder AlderLake is ever clean and best solution, after patch ur dsdt -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
