Hola recientemente he instalado mavericks en mi laptop,solo inicia si utilizo cpus=1 ,pero inicia con un solo core, tambien tengo instalado Lion y con el mismo problema pero lo he solucionado instalando voodootscsync.kext
He probado lapix fix patcher 0.7 obteniendo el mismo resultado
alguna idea??
gracias
un saludo,
Hi I recently installed on my laptop mavericks, only starts if I use cpus = 1, but starts with a single core, also I have installed Lion and the same problem but I solved installing voodootscsync.kext
I tried Lapix 0.7 patcher fix the same result
any ideas?
thanks
a greeting,
you can always use clover.
