Location of EFI OpenCore Serie 300.400 and EFI OpenCore Serie 500 files
Hi,
I have been following this guide:
https://www.redmondpie.com/how-to-install-macos-12-monterey-hackintosh-on-pc-guide/
The guide states the following:
Once this is done, you are pretty much ready to boot the USB drive up on your Intel machine to launch macOS installer. However if you have one of the following PCs with Intel CPU, you need to first add some files in the drive before going ahead with the boot up. If you don’t have the listed Intel CPU, you can totally skip the following sub-step.
  • 4th-gen or below Core i Intel processor (use EFI OpenCore Serie 100.200)
  • 4th-gen or above Core i Intel processor (use EFI OpenCore Serie 300.400 and use EFI OpenCore Serie 500)
Download the required files from Folders section at olarila.com/files/?dir=Folders. Once done, launch Explorer ++ as Administrator in Windows. Here, open the USB drive and delete the EFI folder and files you see in the drive and replace them with the ones you downloaded above.
I am really sorry but I can for the life of me find the EFI OpenCore Serie 300.400 and EFI OpenCore Serie 500 files.
Does anybody have a link?
Any help would be greatly appreciated.
Regards,
Luke
Hi MaLd0n,
Thanks so much for replying. My hardware is as follows:
Motherboard: MSI B250M PRO-VH (MS-7A74)
Proccessor: Processor    Intel(R) Core(TM) i5-7400 CPU @ 3.00GHz, 3000 Mhz, 4 Core(s), 4 Logical Processor(s)
Built-in graphics: Intel(R) HD Graphics 630
HD: Western Digital SSD WDS240G2G0A
Would it be easier to use clover?
I will study the link that you sent and do a bit more research. Sorry for my lack of knowledge, this is my first time.
Thanks again.
Luke
U can use clover or opencore
Hi,
I have made some progress. I created the US stick and replaced the EFI folder with the KabyLake. The SATA made is confirmed AHCI.
When I boot, I see the attached black screen with Reset NVRAM (which I did once) and Toggle SIP.
I don't have a Install MacOS option.
So sorry to bother you but any pointers would be appreciated.
Regards,
Luke
IMG_20220813_082725.zip
use this efi folder
https://olarila.com/files/OPENCORE.MOD1/EFI.Opencore.NoteBook.KabyLake.MOD.zip
-Use USB2 port for easy installation with no remap USB.
-Users with IGPU can use -igfxvesa bootarg for easy installation.
-Delete old EFI folder and paste new. Don't use merge files.
-Don't use Drag and Drop into EFI partition. Use Copy/Paste instead.
-Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen.
Hi,
Thanks so much. I still could not see the Install MacOS and suspected it may be Windows. I tried replacing the EFI folder on Linux and it worked.
All installed and everything works.
Thanks again. Will be donating tomorrow.
Regards,
Luke
ok
Enjoy!
Hi MaLd0n,
Sorry, just a quick one. My Hackintosh is asking me to upgrade to Ventura. Can I do this or will it break things?
Regards,
Luke
update kexts and bootloader and go
i have a laptop which has Intel i5-460M chipset.But the problem is i won't find any EFI file for this version. it's code name is arrandale. How can i find the EFI for this one. TIA
здравствуйте можно ли установить хакинтош на h470m k i3 10100 без дискретной видеокарты
Yes u can. Example here https://www.olarila.com/topic/14351-ga-h410m-h-with-i3-10th-gen-processor-low-price-vanilla-hackintosh/
спасиба
еще у вас есть таблица материнских плат 10 поколение нативных которые можно установить без дискретных видео карты hakintosh
спасибааа
только уменя H410M-K  вотакой не "H" можна ли устанавить
1 hour ago, NoMaUz said:
только уменя
No problem. Just dont use h410 v2 and v3. V1 is good.
