Hi this is my pc:
CPU: Ryzen 7 3700x 8 core
GPU: Gigabyte rtx 2070 super
MOBO: rog strix x-570F
I need help to choose best solution to install and what efi folder i have to pick from the list. I want to install latest stable mac os release monterey but i don't know if is best solution also i need help to pick correct efi folder. Thanks for the help
This nvidia gpu don't have support
I guess only soution is to place a vm on that one
Hmm i have another pc
i7 4790k @4.00ghz
gtx 1070 evga
8 gb ram
 Is there any solution for this one? Maybe with high sierra? Thanks for help again
Edited by Ducky89
Haswell
  • Thanks 1
On 8/9/2022 at 6:24 PM, MaLd0n said:
Haswell
I fully installed mac os High Sierra on my second pc on external drive but i have a problem with the monitor i can't set my resolution to 1920x1080 and it say the system is connected as projector and the only resolution available is 1280x1024.
u need install nvidia web driver
i can't find any driver for mac OS 10.13.6 (17G66) and i tried to update manually since i have no more updates inside appstore but it say is incompatible.  i'm stuck on version 17G66
Edit: ok i got this i downloaded one by one patches in order and updated one by one manually and i installed the driver now with version 17g8037 seems all work fine
Edited by Ducky89
