Hello everyone!
Have VIA VT1802 audio controller.
Works fine with VoodooHDA or patched AppleHDA (except mic).
But i have no sound after wakeup.
While i use VoodooHDA it gives error in dmesg:
error: numPcmDevices is zero
While i use AppleHDA it gives bunch of 'sound assertation in dmesg.
I think it's DSDT releated problem.
I found something about power management here
Help me with this problem
dsdt_last.zip
Just tried :)
Here dmesg before and after (except first 3 lines) sleep:
CodecCommander::init: Initializing
CodecCommander::init: make ASUS
CodecCommander::probe: Probing
CodecCommander::start: Starting
CodecCommander: command 1470c02 written to ICW register
CodecCommander: status of ICB field changed to 1
CodecCommander: get status of IRV field
CodecCommander: response latched in IRR register, IRV returned valid status 2
CodecCommander: command failed, IRV returned invalid status 2
CodecCommander: IRV field cleared, ready for next command
CodecCommander::power: is on
Checked headphones input and it's working.
After sleep i have no sound from internal speakers and internal mic doesn't work.
I think it's HDEF power releated problem.
If you know ACPI Specs, can you take a look on my DSDT
UPDATE
AppleHDA working for VT1802, except internal mic.
Link to patched version for 10.9
