Getting this error message on installation.. "this copy of the install macos monterey application is damaged, and can t be used to install macos"
Please help me to continue the installation.. Thanks - KarthiK
Image downloaded from
Edited by Karthik Gmail
what hardware?
what system version?
CPU - Intel Core i5 8400 @ 2.80GHz, Coffee Lake 14nm Technology
Motherboard - ASUSTeK COMPUTER INC. PRIME H310M-E R2.0 (LGA1151)
Graphic - NVIDIA GeForce GT 710 (ASUStek Computer Inc)
Audio - NVIDIA High Definition Audio
Mine stucks at "An error occurred preparing the software update"
My PC Specs:
Intel i3 12100f - Asus H610M - Asus Dual RX6600 - TeamGroup 2x8Gb 3200Mhz
My EFI is OpenCore for Alderlake
Edited by Ted Greedy
what nvme?
Just now, Ted Greedy said:
I use 2 Ssd sata 3 128gb
Hey pls, cerate a separate topic to discuss this... this is distracting from my issue..  Thank for understanding.
MaLd0n, Any solution or update for my issue ?
Try download last from apple and create usb again
I have downloaded latest PKG from apple store, which way i can create USB. FYI, I am using windows PC
