INTEL 3000 HD Kext and conexant HD audio Kext
Hello all, i have installed osx 10.9(13A603) on my toshiba c640 i5 2.39 ghz 4gb ddr3 1333 mhz intel hd graphics 3000 .
I require help to install the intel hd graphics and audio kext and also the bluetooth kexts please if any one can help me :) please Thanks in advance. and i am noob at this stuffs tried many kexts and all.
THANX :)
hello i tried doing single boot and the following commands but still couldnt get to the graphical enviornment
and now i am again installing mac .
i want the working kext for my mac 10.9 (13A603)
and i am noob at all this so please help me out
i will try to install the chameleon and then try
thankx for ur support :)
to try to solve another problems use this app to identify correctly the hardware
http://Olarila.com/forum/viewtopic.php?f=18&t=63
to the audio u can try here if one of the kext is to u audio
http://Olarila.com/forum/viewtopic.php?f=9&t=1933
thankx artur -pt i solved the graphics issue with out deleteing the kext from the installer ;) and audio also i gt the kext :)
now installing fresh :)
the solution is IntelInject=0 in the args and it worked well :)
and will try the above post :) Thanx \m/
Hello, i am new here.
I really need help, i install Mavericks, 10.9. And everything going great except the Graphics.
My screen is split into 4.
I tried to find the problems, and it was the AppleintelSNBgraphicsFB.kext
If it on S/L/E my screen going split into 4. But, if i put it on the trash, my screen going to normal.
but i get some lag on the screen,
Please Help to solve this problem...
My PC is acer aspire 4750, with Intel HD 3000, HM65 chipset, and intel core i5-2430 processor.
Then you don't need the DualLink property.
Remove the DSDT patch/EFI string (or disable graphics injection/enabler).
Hello sir. thanks for the quick response..
How I can do these things??
"Remove the DSDT patch/EFI string (or disable graphics
injection/enabler).."
can you give some tutorial..
sorry for that.. I am totally new..
I have no idea what you have done in post install, it's impossible to be more specific unless you give more details.
I just do the normal installation sir..
write the Raw into USB and boot it.
On do not make any change on installer amd I do not make ane change on clover configuration.
On installation progress my screen already split into 4.
after some research on removing kext I found if the apleintelsnbgraphics is the problem.
so.. on the next installation..
on the first booting by Hard disk I remove the appleintelSNBgraphicsFB to make screen going normal.
I do not know how to remove the DSDT patch like you said..
Disable graphics injection in config.plist or uncheck it in options menu, then you should not need to remove any kext
http://clover-wiki.zetam.org/Configuration/Graphics#Inject
Thank you sir, it worked !!
My screen is normal, not split again.
But, i get freeze on my start up when i boot from hard disk.
So, i follow the instruction which said to entry on single user mode (-s) and then move IntelHD kext to Backup folder.
It was succes to bring me entry the graphical environment.
But i am confused on changing SMBIOS.plist.
On my mac, it said if my mac is "imac"
I try to change it to MacBookPro8.1 using chameleon wizard,
Chameleon wizard said there is no SMBIOS.plist, so i generate one and save it on Document folder.
But, it not change my mac from imac to macbookpro..
I try to make Extra Folder on system, and put it there, but it also not work..
What i must do next?
Where i must put the SMBIOS.plist to make it work??
I use clover on boot with Flash disk USB and install it to hard disk.
But,I install chameleon bootloader on my hard disk.. Not clover..
So, what i must do?
I still need to insert data on config.plist??
Then just save smbios.plist in /Extra, it should work.
I'm not sure what you mean with that, but the Extra folder must be in root, not in "System" folder.
sudo mkdir /Extra
sudo mv Documents/SMBIOS.plist /Extra
it worked!!!!
thanks very much sir.. you save my day..
about extra folder on system, it was my mistake.
hahahaha...
I know now the extra folder must be on root, not inside on system folder.. LOL..
