Upadate 10.9 GM (Build 13A598) to 10.9 (Build 13A603)
Hi,
Is there any way/ clue to update from 10.9 GM (Build 13A598) to 10.9 (Build 13A603)?
I have 10.9 GM (Build 13A598) running okay (except the sleep) in my laptop and wondering if anybody already made an attempt to update to the latest mavericks build?
Thanks a lot! ;)
Hello
If you have Clover as bootloader you can update from AppStore without problem, but if you have Chameleon, you'll need make a usb installer with MV(13A603) and install
Only real mac or hack with EFI bootloader can update from AppStore.
Hi, unfortunately I use Chameleon. Do you mean I need to do it all over again by creating USB installer with latest build and reinstall again? oh man :o
Is there any work around without sacrificing my current installer that already running? is there any tutorial that I can read and follows?
Thanks a lot!
Hello
Yes, but i don't know if anyone made a bootable image with this new build(13A603)
if not you'll have make one... follow the guide given by pernacabeluda
No, excuse me, but... no. You'll need install all things again... in this new installation you can try use Clover...
How about if I change or migrate my bootloader in my current installation to clover? is it possible to do that? or it not worth rather that just do the clean installation from beginning?
Hello
Maybe... i don't think a good idea overwrite an bootloader installer another, but you can try
Remeber, you'll have to configure everything again... Clover isn't Chameleon.
