Hello Guys,
I already try using EFI from
 but still no luck, always stuck on Stuck on [EB|#LOG:EXITBS:START]
The PC is Dell Optiplex 5040 SFF with specs:
- Proc: Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
- RAM: DDR3 16GB
- iGPU: Intel HD Graphics 530
- SSD: 256GB
- Network: Intel Ethernet Connection (2) I219-V PCI
Anyone have tips how to get working?
Thank you.
Edited by Alex K
add iGPU
use skylake efi desktop folder with -igfxvesa for now
I try that also, but still no luck :(
Hi MaLd0n,
I already follow those instructions, but still got the same error / stuck.
Thank you for your reply.
u need play with quirks for check what quirk cause this problem
Which quirks?
Booter? Kernel? or EUFI?
Thank you.
2 hours ago, Alex K said:
Booter
