It will not work when I try to select “Install MacOS Monterey”, ( No error code ) the screen goes black and then it just goes back to the same screen ( listing “Install MacOS Monterey”, “Reset NVRAM”, and “Enable SIP” ) I reset the NVRAM once and tried again with SIP enabled ( not sure what it was ). I am using efi folder “Opencore NoteBook IceLake”. I am not sure if I am using the correct efi folder. I Googled my cpu (Intel(R) Core(TM) i3-1005G1 CPU @ 1.20GHz) and the code name is IceLake, on the Intel page it says formerly IceLake (Which is why I think I might have the wrong efi folder as I bought the laptop after the date on the page?? ) Any help would be greatly appreciated and thank you for such a supportive community!! :)
Edited by STARLIT_bc
Not worded well and made a typo
