Monterey 12.4 Bluetooth not working
BlueToolFixup.kext
BrcmFirmwareData.kext
BrcmPatchRAM3.kext
Still bluetooth doesn't opening with new DSDT.
Edit1: With this change, now at the About This Mac > System Report, Bluetooth window doesnt contain anything. And I think the battery indicator not working anymore. (I will try to restart a few times to test about the battery, but by now it is stucked).
Edit2: The battery indicator stucked at 92% with the new DSDT even after a reboot.
Edited by enolic
dsdt is same i just remove one little patch about BT
hmm then why the battery status stucked? idk but the bluetooth didnt work with removed patch
does the IntelBluetoothFirmware.kext required for me?
u need use these kexts
BlueToolFixup.kext
BrcmPatchRAM3.kext
edit: With old DSDT the laptop every time powered on, first hard shutdown itself (i think this is makes battery working) and after that power on itself again. With the new DSDT the laptop dont hardshutdown itself on the power on.
I have exactly these kexts, but the bluetooth doesnt work
spacer.pngThese are all the kext I'm using with bootloader
no
only for BT intel
Then there is no any way to fix this.!?!?
We tried with the DSDT you sent me but with no result. I tried 3 kexts you told me (2.6.1 and 2.6.3 versions) but with no result again.
I connected an external Bluetooth adapter (TP Link UB400) but it is not working either.
post ur full efi folder here
Unfortunately didnt help ? The bluetooth section on Preferences now cant load completely:
And the battery doesn't work with the new EFI
idk what happens
test with clean install
