Gigabyte Z390 AORUS PRO + 2xRX580 + Aquantia AQ107
Hi. I updated from Mojave to Monterey. System is working but there is a problem with external USB3 drives - it takes ages to mount USB3 SSD drive (on usb2 or macbook - immediately).  Probably I messed up a bit. Any help appreciated. Under Mojave it works ok.
Send me Grzegorzs-iMac.zip
Yes, Thank You, now is much better.
I had to change was to uncheck "DisableIoMapper" to get Aquantia works. External drives mounts reasonably quick.
The only thing is fans getting very loud for a moment on start or after wake up. There is ioreg in attachment.
iMac.zip
if u using iMac19 smbios u need enable IGPU for hardware accel or change smbios to iMacPro1,1 or MacPro7,1 with no IGPU enable
common in some cards
Sorry - there is another problem. After sleep clock shows incorrect time, I have to go to the panel, unlock, change time manually. Have you meet something like that? Could generate problems with saving files and backups.
try disable "disablertcchecksun" quirk
