Catalina 10.15 Open Core Can not boot need installation help
hello every one
i am new to mac
 have laptop lifebook e5510
cpu: commet lake
gpu : uhd 620
i downloaded catalina 10.15 and make Efi Folder and i am stuck  on watchdog status 0
EFI.rar
what i can do???
Use Olarila efi folder for comet lake notebook with -igfxvesa for easy installation
https://www.olarila.com/topic/5676-hackintosh-efi-folder-for-all-chipsets-clover-and-opencore-macos/
check ur procedure
read post above
i did what u told me but it stuck now at
and repeat to bios and windows
with this configlist can u check it
config.plist.zip
is wrong
a wrong procedure
if u use olarila efi need appear theme etc
i  have many of os
which u suggest to use for 1st time and easy for instalment
macOS_Catalina_10.15_19A583.dmg
Olarila BigSur 11.6.7.raw
Olarila Catalina 10.5.7.raw
Olarila Mojave 10.14.6 18G95.raw
Olarila Monterey 12.3.raw
High Sierra 10.13.6 17G2208.dmg
OSX-Mavericks.dmg
need your  help through installment and setup please
Edited by Habooob
Both. just go
