Aquitaine Posted June 26, 2022 Posted June 26, 2022 Hi guys I tried to install to my PC and it seems to get stuck at some point, it tries to launch the install after checking dmg etc - I can provide a photo if that helps maybe? My hardware is : CPU: Intel(R) Core(TM) i5-9400 CPU Chipset: Intel B365 (Kaby Lake) GPU: Intel UHD Graphics 630 (Coffee Lake-S GT2) [DELL] Secure boot and Hypervisor (HVCI) disabled I connect to my monitor via HDMI not sure if that causes issues either. Thanks for the help and I hope we can get the Monterey installed : )
Administrators MaLd0n Posted June 26, 2022 Administrators Posted June 26, 2022 -Use USB2 port for easy installation with no remap USB -Users with IGPU can use -igfxvesa bootarg for easy installation -Delete old EFI folder and paste new. Don't use merge files -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead -Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Aquitaine Posted June 26, 2022 Author Posted June 26, 2022 I didn't try the USB2 or the -Users with IGPU can use -igfxvesa bootarg for easy installation Let me try that and get back to you. Thanks for the quick response - here's to hoping it works.
Aquitaine Posted June 27, 2022 Author Posted June 27, 2022 Tried via the USB 2 but no changes really - still gets stuck Can someone advise how to boot with -igfxvesa not sure where to add that option in, should I try to put that into the config.plist?
Administrators MaLd0n Posted June 27, 2022 Administrators Posted June 27, 2022 add this bootarg in config.plist, nvram tab 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Aquitaine Posted June 28, 2022 Author Posted June 28, 2022 wow! It booted up and installed after those two changes! You're a star!
Aquitaine Posted June 30, 2022 Author Posted June 30, 2022 Any idea if the Wifi can work on the Atheros 9565 on Monterey? I tried the kexts mentioned here but nothing seems to work. Should I just buy an external card?
Administrators MaLd0n Posted June 30, 2022 Administrators Posted June 30, 2022 no. need change -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
