problems with sleep and wake and power management su b360-m core i3 9100f
Could you help me with my DSDT tables, my hardware is an asus b60m-a board, with core i3 9100f processor, with gt710 2gb graphics, ssd disk.... I managed to start without problems with the guide on this page, later I managed to repair the acceleration graph, but currently I have problems with sleep, my machine never goes to sleep, I think the energy management has faults and the front panel audio I have not been able to correct it
Send me iMac-Pro 2.zip
first start with olarila efi folder coffeelake
u dont need it. olarila efi have all
Currently I have problems detecting the USB3.0 of the usbTypeC port and the front USB3.0 port of my box, it only detects them as HS0xxxx...... My machine has a 300 series board, asus b360m-a, running "Monterrrey 12.4", I wanted to know if these kexts are necessary for my system:
CPUFriends.kext
RTCMemory.ketx
SMCSuperIO.ketx
VirtualSMC.ketx
SMCProcessor.ketx
Do I have to put them in my EFI, or are they not necessary?
change my SMBIOS is iMacoPro1,1 for iMac19,1
I followed the published usb tutorial
https://drive.google.com/file/d/1OjxzksMackIqxhUIhYjrFUcYmb8tUre0/view?usp=sharing
ur remap is wrong
u kill many usb3 ports
we have limit 15 ports and one physical port = 2 ports(HSxx and SSxx)
I understand, I will carry out the process again... could you tell me if these kext are necessary for my system if I have the oralilla ssdt?
CPUFriends.kext
RTCMemory.ketx
SMCSuperIO.ketx
SMCProcessor.ketx
Use olarila efi folder and remove unnecessary lan kexts only
