Hi everyone! Everytime i want to format the partition i made in windows to Macos journaled or apfs it says "Erase process has failed" with message:"mediakit reports not enough space on device for requested operation".but the partiton is 64gb so idk what is the problem. then i cannot even mount the partition, i have to reformat it in windows. What should i do? (the hdd i wanna install macos on is in use and thats why i dont format the entire drive.)
