problem when update from 10.8.5 to mavericks
I use the whole night to dl the update file from the appstore, after finish dl the update file when i click install , it show me this error .
What can do , if i dont want to format hdd again and also can update to Mavericks. PLS anyone can help me ?? :|:|
Hello.
If you use Chameleon… i’ll need make a usb installer with new MV and install.
Only real Mac or hack with EFI bootloader(Clover) can update osx from AppStore.
OIC...thank you , 1 more question , if use usb installer can just update or not ?
because i dont want to reformat my hdd, and me install too many software and lazy reinstall it again.
u can try .. is a mess system u are creating.. but is u choice.
the first problem u have mbr partition.. mac don't use that.. so the installer app must be modified.. to support that
anyway like u have donne is for mac or for people using a efi loader like clover..
my advice is to do a clean install..
thank you artur-pt , i prepare to do a clean install . after finish install will post here . ;)
