Need Help ... Bluetooth and headphones port doesn't work
My Bluetooth doesn't work in montery even after installinh the 2 kexts provided by the admin to fix but i didn't know to patch them in config.plist also i have another problem my audio is working and also the microphone but the headphones jack doesn't so is there anu solution please ?
thanks btw about the hard effort that is doing here.
i use macOSMontery and everything is work Except these 2
Edited by ScorpionTaj
need check solution for bt under 12.4. apple change some things
like what ? can you guide me into it ?
