need help with H410M-A-Pro core i3 10100 + RX 6600
I'm running on Monterey 12.4 and it was working properly when using integrated GPU UHD 630, and then I got a new graphics card which is Sapphire RX 6600. After I installed the graphics card, I added the boot-args agdpmod=pikera but its not working. My hackintosh stuck at boot, sometimes black screen.
Do I need to do a fresh install or there is anything I can tweak? I hope you guys can help me with this :)
here is my working EFI folder that worked with UHD 630:
https://www.mediafire.com/file/i83y37jv60li87w/H410M-A-Pro_EFI.zip/file
update kexts, bootloader, change ur smbios to iMacPro1,1 and stay with agdpmod=pikera with IGPU disable
https://www.olarila.com/topic/24542-opencore_no_acpi-opencore-with-additional-featureschanges-implemented-how-to-use-this-fork/
