have u disable the hd 4000 onboard ?
are u booting with GraphicsEnabler=No for the nvidia ?
It must be Mac Os Extended (Journaled)
Dear ,, when u said disk utilities
I though i must format it from windows
I did not know that the utilities is on the same instalation page
Thanks a lot for help
Realy happy :-)
Hello again ,,
After finish the instalation and reboot
It return to the calver screen ,,
I try to choose the H.disk where i install it
It give me need a boot disk !?
Hello again ,,
Iam useing the .raw usb to insall
I found that it took too much time to install
Then after the blue bar have less than a min to install
A blank black screen start without giveing me its finish before it come to the end of the bar
And start again reebting !
That what i face .
I reformat the usb from
Disk part clean
The adminstative tools new volume
And start again to copy to rhe usb as a clean one
I entered the disk utilities and erase it as a mac osx jornaled
And start again
But it return the same
Instalation screen before it finish it reboot
Coz of that i am stucked and cant go forward .
how do u prepare the pen ?
in windows ?
if so format the all space in ntfs in windows
and run the program to burn it
the same ,,,,
this is the video error its on 2:53 second >>>
I reformatted the pen drive to nfts and install the .raw file and its only stocked at less than minute bar more then 20 minutes ?!
and an image in attachment about the errors
hope to sove it ,,,
thanks in advance
Hello Every one I am Getting this Kernel Panic, :roll:
I was Runnig Perfect Ml10.8.1,now doin Hackintosh for Mavericks,Recently Installed it,I am Using Latest Chamelion Wizard,& Updated the Bootloader Using Cwizard.
Thanx in advance
Dell Vostro 3550, i5-2450M(2.50 GHz-Turbo Boost3.10 GHz) , RAM - 4 GB , Graphic - ATI Mobility Radeon HD 6630m 1GB(Switchable Graphics) , Chipset Intel PCH HM67, Yosmite 10.10/ Win 8.1 Pro x64/ Dualboot Chamelionwizard
Hello. I somewhat successfully installed Mavericks, but I can't boot from HDD. I get the boot0 error. I used the .raw file to do a clean install and used multi b**** post install. I am open to Clover, I just didn't know what the difference was. I am a noob, so please don't assume I've already tried something or done something a certain way. I will appreciate all suggestions. Ultimate question is: How can I get past the boot0 error to boot Mavericks from HDD without USB stick?
Oh and my system looks like:
Z77-DS3H (Rev 1.1, BIOS version F8)
i5 3570K
Seagate Barracuda HDD
Crucial Ballistix Sport RAM
Radeon HD 7750 GPU
Thank you so much!
if u want our help u use the forum methods no " beast " thing
about boot error
http://Olarila.com/forum/viewtopic.php?f=28&t=1676
clover same procedure
ok, sorry for referencing that! thank you for the reply. i tried that solution without the bs=4096 and it didn't work for me. it actually changed my boot0 error to a boot0 error with a screen full of jumbled characters. i will try again and post the results. a general question i have is: is it impossible for the boot0 error to be caused by anything other than the block size of my drive? thank you.
if u have a hd 4k.. always have boot0 error
the junk in screen is from u graphics starting reading about here and google for..
http://Olarila.com/forum/viewtopic.php?f=28&t=736
with u config don't expect a easy install ... like windows.. so start reading about what u are trying to do
I took the 7750 out and booted from HDD without problems. I should have done this from the start, but thought I could just enable IGFX from BIOS. Thank you for the help, and I will use your article to help set up my 7750 now. Thank you!
Hello! Thank for the torrent.
I can use an external ssd or Hdd to make the usb boot drive?
Edit: I mean, use an external an ssd or hdd to copy the installation files.
