Hi Everyone,
I'm newbie
i have a hdd 500gb to install Mavericks,old hdd 80GB, and 2GB USB, i don't have a 8G USB, i wonder can we write .raw file to HDD 80GB to install mavericks?
Hello i have a problem with the Mavericks installation.
First i followed the tutorial EXACTLY and because it froze right before the installer i moved the kext files. But as i want to try an boot it shows a bit more (the gray colored background with an apple in the middle and the cursor is the rainbow of death or how do you call it) and then i tryed and tryed untill it somehow boot up to the installation but it didnt recognise my hdd because i didnt have it set to AHCI in the BIOS. Now when i rebooted it doesn't work tryed it like for 50 times and no luck it says something about the keys that werent found and the "network delay not specified defaulting to 0x384" message.
Sorry for my bad english. If you can please help.
Hi Everyone,
I'm newbie
Today, a good news is i installed successful Mavericks to my HDD 500GB by HDD method, i write raw file to HDD 80GB with HDDRawCopy program (http://hddguru.com/software/HDD-Raw-Copy-Tool/)
and select boot with HDD 80GB first, and we can install mavericks as usb installation method.
Now i trying to install clover bootloader.
Hey guys :)
This is my very first post on forums. I'm totally new in MAC OS X and hackintosh, so please exuse my silly questions.
I just got new PC with following sppecs:
Proc: i7 4770k
Motherboard: ASUS Maximus VI Hero
RAM: Kingston 16GB DDR3 2400 Mhz
GPU: AMD Radeon R9 200 Series
With that spec, I'm 100% sure that I'm able to run Mavericks OS =). I've got 3 Hard drives in my computer. 120gb SSD for my windows, 1TB for programs, games, downloads... (for Windows),
And empty 500gb HDD for my future MAC OS X.
I've downloaded .raw file, writed it on USB with Win32DiskImager. At this step I need to boot it from bios (UEFI). I put USB prio to #1, but there's no response, it boots in Windows normaly.
This is where I get stucked, on very begining xD.
Would be really grateful for any help,
Regards :)
actually i already got rid of using usb everytime. i did this by
1. Installing latest clover
2. mounted EFI folders of hard disk and usb from terminal on desktop.
3. Copied EFI from USB to Hard disk.......reboot..
4. Booted from clover of hard disk.
Then I didnt need to boot from USB.
Now the problem is cpus=1.. is the solution mentioned above is for both issues or just for cpus=1??
I appreciate your assistance.
http://clover-wiki.zetam.org/Configuration/KernelAndKextPatches#KernelLapic
HP notebooks have lapic problems, which can be solved by using the boot parameter cpus=1 or by using this option.
Insert it in your config.plist
	<key>KernelAndKextPatches</key>
<dict>
	<key>KernelLapic</key>
	<true/>
</dict>
If you don't take the time to read the documentation you will never get things working properly.
If you did that, you already have it, just need to edit.
Find what?
Seriously man, if you can't figure this out, just forget it, hackintosh is not for you.
Burn the .raw to usb stick
Boot from the bios
I reache the instalation sceen
I choose the H.disk but i recognize it must be formated as fat32
I just reformat it as a fat32 from Diskpart ... Administral tools
Now iam trying to install it again but it never appear the instalation sceen as the 1st time.
Its like its stuck in some where ,,
Do shall i change in its instalation option !?
The hard disks are on AHCI
And its boot option in bios is UFEI checked .
DZ77GA-70k
Nevidia 660 ti
Ram 8g
CPU i7-3770
It must be Mac Os Extended (Journaled)
You need at least one free partition, use Disk Utility (in the Utilities menu) to erase it as Mac Os Extended (Journaled).
