The correct is the one in the OP
MD5 (OS X 10.9 Install USB.raw) = 6179a219e1bf7634fb321fabb8d3288d
The other I posted is from previous version (13A598).
So I've installed Mavericks on my HP-1000 Notebook with Clover installed in HDD.
Many thanks to staff for cooperation and guidance!
A bit more of help needed to:
- - Get my WiFi working
- - Get my Nexus 4 recognised by Mavericks to transfer files
Regards!
Not working:
- Intel HD4000 Graphics (looking for a solution...)
- Touchpad (looking for a solution...)
- Wi-Fi (and it won't)
- Audio (looking for a solution...)
No tested:
- HDMI out
- VGA out
I think that's all. I'll keep searching and googling, as I always do because I want to learn, not only try other's answers.
"WiFi won't work" -- said for one system for some reason or any general bug..?
It depends on the hardware (vendor/model). Which one is yours?
hi frnds, am new to this hackintosh thing.am facing problem in booting the installer from USB. i downloaded this raw image and made bootable usb but unable to load..i get [usb is failed ] message while i boot from usb.. plz help..
my lap config
Toshiba a665-s6094
Toshiba nwqaa motherboard
intel i7 740qm
4gb ram
512mb geforce 310m
UEFI bios (no legacy boot)
I'm still stucked at enabling full HD4000 graphics. This is what I got:
This is my org.chameleon.Boot.plist:
<key>Graphics Mode</key>
       <string>1366x768x32</string>
       <key>GraphicsEnabler</key>
       <string>Yes</string>
       <key>IGPEnabler</key>
       <key>RestartFix</key>
       <string>No</string>
       <key>SMBIOS</key>
       <string>/Extra/SMBios.plist</string>
       <key>SystemType</key>
       <string>2</string>
       <key>IntelCapriFB</key>
       <string>1</string>
When I added the IntelCapriFB key and string, it enabled all the stuff of the screenshots above, but the animations are horrible and laggy. I'm loading the following kexts:
- AppleIntelFramebufferCapri.kext
- AppleIntelSNBGraphicsFB.kext
If I add the AppleIntelHD4000Graphics*.kext/bundle, the OS gets stucked at the Bluetooth Transport missing message :/
I have not tested all IntelCarpiFB strings (from 0 to 11, but just tested 0 and 1) because I'm not sure if it will change anything.
Do you have any idea of how can I enable full HD4000 graphics? The screens resolutions is OK, but animations are laggy .
Thank you in advance.
P.S: I've tried a lot of other ways, and this has been the only one that the OS is recognising integrated HD4000.
Asus k55VD - Core™ i7 3670QM - Intel® Chief River Chipset HM76 - 6GB DDR3 RAM - Altec Lansing® - NVIDIA® GeForce® 610M with 2GB DDR3 VRAM and Intel HD Graphics 4000 - DUALBoot with Mavericks 10.9.5 and Windows 8.1 Pro
have u read the guide to hd 4000 i think u don't
the nvidia don't work at all .. that u show is only cosmetic
optimus don't work in mac os x
and u should try all mobiles ig-platform-id
like u see in system info .. no kext loaded..
http://Olarila.com/forum/viewtopic.php?f=28&t=3111
Yes I read it. I tried the chameleon injection method (that's why I have IGPEnabler and and IntelCapriFB keys on my org.boot... plist. I tried from 0 to 11 and it didn't work, so I tried the 'old' method by using the hex string. Tried from 0 to B with no success... In Mountain Lion I got it working with hex string number 3 (0x01660003).
i'm sure u are doing something wrong.. if it works with that string in ML.. must work here..
the string is always the same.. in any mac os x version...
I'll revise everything again and I'll post my results.
Thank you.
P.S: Elan TouchPad working with MiltiTouch features (except scrolling :/ ), Altec Lansing audio also working. Not working: Wi-Fi, camera, full hd4000 graphics.
I'm on the right way but still have no full accelerated graphics...
kextstat is reporting the following:
Index Refs Address            Size       Wired      Name (Version) <Linked Against>
   1   55 0xffffff7f807df000 0x8d80     0x8d80     com.apple.kpi.bsd (13.0.0)
   2    6 0xffffff7f80b8e000 0x28c0     0x28c0     com.apple.kpi.dsep (13.0.0)
   3   77 0xffffff7f807a8000 0x1dfb0    0x1dfb0    com.apple.kpi.iokit (13.0.0)
   4   83 0xffffff7f807c6000 0xbf40     0xbf40     com.apple.kpi.libkern (13.0.0)
   5   71 0xffffff7f807a5000 0x2d10     0x2d10     com.apple.kpi.mach (13.0.0)
   6   34 0xffffff7f807d2000 0x7d40     0x7d40     com.apple.kpi.private (13.0.0)
   7   51 0xffffff7f807da000 0x48e0     0x48e0     com.apple.kpi.unsupported (13.0.0)
   8    0 0xffffff7f80c26000 0xb000     0xb000     com.apple.kec.pthread (1) <7 6 5 4 1>
   9    2 0xffffff7f80e7e000 0x47000    0x47000    com.apple.kec.corecrypto (1.0) <7 6 5 4 3 1>
  10   15 0xffffff7f81167000 0x9000     0x9000     com.apple.iokit.IOACPIFamily (1.4) <7 6 4 3>
  11   16 0xffffff7f808ba000 0x2d000    0x2d000    com.apple.iokit.IOPCIFamily (2.8) <7 6 5 4 3>
  12    2 0xffffff7f81b2a000 0x5f000    0x5f000    com.apple.driver.AppleACPIPlatform (2.0) <11 10 7 6 5 4 3 1>
  13    0 0xffffff7f813c6000 0x2000     0x2000     es.osx86.driver.EvOreboot (1.0.3) <4 3>
  14    0 0xffffff7f80c31000 0x2000     0x2000     org.tgwbd.driver.NullCPUPowerManagement (1.0.0d2) <7 4 3>
  15    1 0xffffff7f80ec5000 0xb000     0xb000     com.apple.driver.AppleFDEKeyStore (28.30) <9 7 6 5 4 3 1>
  16    1 0xffffff7f81156000 0x11000    0x11000    com.apple.iokit.IOReportFamily (21) <5 4 3>
  17    8 0xffffff7f807e8000 0x2d000    0x2d000    com.apple.iokit.IOStorageFamily (1.9) <7 6 5 4 3 1>
  18    0 0xffffff7f811bb000 0x1e000    0x1e000    com.apple.driver.DiskImages (371.1) <17 7 6 5 4 3 1>
  19    0 0xffffff7f81876000 0x14000    0x14000    com.apple.driver.AppleKeyStore (2) <9 7 6 5 4 3 1>
  20    0 0xffffff7f81a35000 0x2b000    0x2b000    com.apple.driver.AppleIntelCPUPowerManagement (216.0.0) <7 6 5 4 3 1>
  21    0 0xffffff7f80b91000 0x3000     0x3000     com.apple.security.TMSafetyNet (7) <7 6 5 4 2 1>
  22    2 0xffffff7f80b94000 0x5000     0x5000     com.apple.kext.AppleMatch (1.0.0d1) <4 1>
  23    1 0xffffff7f80b99000 0x14000    0x14000    com.apple.security.sandbox (278.10) <22 7 6 5 4 3 2 1>
  24    0 0xffffff7f80c1e000 0x7000     0x7000     com.apple.security.quarantine (3) <23 22 7 6 5 4 2 1>
  25    0 0xffffff7f81b9a000 0x8000     0x8000     com.apple.nke.applicationfirewall (153) <7 6 5 4 3 1>
  26    0 0xffffff7f81af8000 0x3000     0x3000     com.apple.driver.AppleAPIC (1.7) <4 3>
  27    2 0xffffff7f810f9000 0x4000     0x4000     com.apple.iokit.IOSMBusFamily (1.1) <5 4 3>
  28    0 0xffffff7f81b89000 0x7000     0x7000     com.apple.driver.AppleACPIEC (2.0) <27 12 10 5 4 3>
  29    0 0xffffff7f81758000 0x4000     0x4000     com.apple.driver.AppleSMBIOS (2.0) <7 4 3>
  30    0 0xffffff7f81a8c000 0x3000     0x3000     com.apple.driver.AppleHPET (1.8) <10 7 5 4 3>
  31    0 0xffffff7f81819000 0x3000     0x3000     com.apple.AppleACPIPS2Nub (1.1) <10 7 4 3>
  33    4 0xffffff7f80ed0000 0x85000    0x85000    com.apple.iokit.IOHIDFamily (2.0.0) <15 7 6 5 4 3 2 1>
  34    0 0xffffff7f81b93000 0x4000     0x4000     com.apple.driver.AppleACPIButtons (2.0) <33 12 10 7 6 5 4 3 1>
  35    2 0xffffff7f817db000 0x13000    0x13000    com.apple.ApplePS2Controller (2.8.3) <5 4 3>
  36    0 0xffffff7f813b0000 0x16000    0x16000    org.netkas.driver.FakeSMC (820) <10 7 5 4 3 1>
  38    1 0xffffff7f81ad3000 0x5000     0x5000     com.apple.driver.AppleEFIRuntime (2.0) <7 6 5 4 3>
  39    0 0xffffff7f81784000 0x7000     0x7000     com.apple.driver.AppleRTC (2.0) <10 5 4 3 1>
  40    0 0xffffff7f8180b000 0xa000     0xa000     com.apple.ApplePS2Keyboard (2.8.3) <35 33 5 4 3>
  41    0 0xffffff7f81ad8000 0xa000     0xa000     com.apple.driver.AppleEFINVRAM (2.0) <38 7 6 5 4 3>
  42    2 0xffffff7f80bad000 0x34000    0x34000    com.apple.iokit.IONetworkingFamily (3.2) <7 6 5 4 3 1>
  43    0 0xffffff7f814b6000 0x9000     0x9000     com.apple.BootCache (35) <7 6 5 4 3 1>
  44    0 0xffffff7f81ac4000 0x4000     0x4000     com.apple.AppleFSCompression.AppleFSCompressionTypeZlib (1.0.0d1) <6 4 3 2 1>
  45    0 0xffffff7f81aca000 0x3000     0x3000     com.apple.AppleFSCompression.AppleFSCompressionTypeDataless (1.0.0d1) <7 6 4 3 2 1>
  46    7 0xffffff7f80dfc000 0x6b000    0x6b000    com.apple.iokit.IOUSBFamily (650.4.4) <11 7 5 4 3 1>
  47    0 0xffffff7f81397000 0x19000    0x19000    net.osx86.kexts.GenericUSBXHCI (1.2.6) <46 11 7 5 4 3>
  48    0 0xffffff7f80fe1000 0x18000    0x18000    com.apple.driver.AppleUSBEHCI (650.4.1) <46 11 7 5 4 3 1>
  49    0 0xffffff7f81ac1000 0x2000     0x2000     net.osrom.kext.Disabler (1.0.1) <4 3>
  50    3 0xffffff7f8134d000 0x19000    0x19000    com.apple.iokit.IOAHCIFamily (2.6.0) <5 4 3 1>
  51    0 0xffffff7f81afd000 0x1a000    0x1a000    com.apple.driver.AppleAHCIPort (2.9.5) <50 11 5 4 3 1>
  53    0 0xffffff7f80be1000 0x34000    0x34000    com.lnx2mac.driver.RealtekRTL81xx (0.0.90) <42 11 5 4 3 1>
  54    0 0xffffff7f80e7b000 0x3000     0x3000     com.apple.iokit.IOUSBUserClient (650.4.4) <46 7 5 4 3 1>
  55    0 0xffffff7f80fc3000 0x17000    0x17000    com.apple.driver.AppleUSBHub (650.4.4) <46 5 4 3 1>
  56    0 0xffffff7f81373000 0x17000    0x17000    com.apple.iokit.IOAHCIBlockStorage (2.4.0) <50 17 6 5 4 3 1>
  57    3 0xffffff7f80878000 0x31000    0x31000    com.apple.iokit.IOSCSIArchitectureModelFamily (3.6.0) <5 4 3 1>
  58    0 0xffffff7f81366000 0xd000     0xd000     com.apple.iokit.IOAHCISerialATAPI (2.6.0) <57 50 5 4 3 1>
  59    0 0xffffff7f815fa000 0x3000     0x3000     com.apple.driver.XsanFilter (404) <17 5 4 3 1>
  61    0 0xffffff7f81102000 0x7000     0x7000     com.apple.iokit.SCSITaskUserClient (3.6.0) <57 17 5 4 3 1>
  62    3 0xffffff7f8110d000 0x11000    0x11000    com.apple.iokit.IOCDStorageFamily (1.7.1) <17 5 4 3 1>
  63    2 0xffffff7f8111e000 0xe000     0xe000     com.apple.iokit.IODVDStorageFamily (1.7.1) <62 17 5 4 3 1>
  64    1 0xffffff7f8112c000 0xc000     0xc000     com.apple.iokit.IOBDStorageFamily (1.7) <63 62 17 5 4 3 1>
  65    0 0xffffff7f81138000 0x1e000    0x1e000    com.apple.iokit.IOSCSIMultimediaCommandsDevice (3.6.0) <64 63 62 57 17 5 4 3 1>
  66    0 0xffffff7f80f5e000 0x7000     0x7000     com.apple.driver.AppleUSBComposite (650.4.0) <46 4 3 1>
  67    0 0xffffff7f817ee000 0x18000    0x18000    com.apple.ApplePS2ElanTouchpad (2.8.3) <35 33 5 4 3>
  68    5 0xffffff7f80c8f000 0x43000    0x43000    com.apple.iokit.IOGraphicsFamily (2.3.6) <11 7 5 4 3 1>
  69    0 0xffffff7f80cd2000 0x10000    0x10000    com.apple.iokit.IONDRVSupport (2.3.6) <68 11 7 5 4 3>
  70    3 0xffffff7f81170000 0xa000     0xa000     com.apple.driver.IOPlatformPluginFamily (5.5.1d27) <10 7 6 5 4 3>
  71    1 0xffffff7f8117f000 0x14000    0x14000    com.apple.driver.IOPlatformPluginLegacy (1.0.0) <70 10 7 6 5 4 3>
  72    2 0xffffff7f81193000 0x11000    0x11000    com.apple.driver.AppleSMC (3.1.6d1) <10 7 5 4 3>
  73    0 0xffffff7f811a4000 0x10000    0x10000    com.apple.driver.ACPI_SMC_PlatformPlugin (1.0.0) <72 71 70 11 10 7 6 5 4 3>
  74    1 0xffffff7f8194a000 0x6000     0x6000     com.apple.AppleGraphicsDeviceControl (3.4.12) <7 6 5 4 3 1>
  75    1 0xffffff7f81950000 0x72000    0x72000    com.apple.iokit.IOAcceleratorFamily2 (98.7.1) <68 11 7 6 5 4 3 1>
  76    0 0xffffff7f819c2000 0x57000    0x57000    com.apple.driver.AppleIntelFramebufferCapri (8.1.8) <75 74 68 11 10 7 6 5 4 3 1>
  77    0 0xffffff7f81a68000 0x3000     0x3000     com.apple.driver.AppleHWAccess (1) <7 5 4 3>
  78    1 0xffffff7f80b1e000 0x11000    0x11000    com.apple.kext.OSvKernDSPLib (1.14) <5 4>
  79    1 0xffffff7f80b2f000 0x37000    0x37000    com.apple.iokit.IOAudioFamily (1.9.4fc11) <78 5 4 3 1>
  80    0 0xffffff7f80b66000 0x20000    0x20000    org.voodoo.driver.VoodooHDA (2.8.0) <79 11 7 5 4 3>
  81    0 0xffffff7f8186e000 0x3000     0x3000     com.apple.driver.AppleLPC (1.7.0) <70 11 5 4 3>
  84    0 0xffffff7f813ce000 0x5000     0x5000     com.apple.Dont_Steal_Mac_OS_X (7.0.0) <72 7 4 3 1>
  86    1 0xffffff7f81825000 0x11000    0x11000    com.apple.driver.AppleSMBusController (1.0.11d1) <27 11 10 5 4 3>
  87    0 0xffffff7f81836000 0xd000     0xd000     com.apple.driver.AppleMCCSControl (1.1.12) <86 68 11 10 7 5 4 3 1>
  88    0 0xffffff7f8126c000 0xad000    0xad000    com.apple.iokit.IOBluetoothFamily (4.2.0f6) <46 16 7 5 4 3 1>
  89    0 0xffffff7f8164f000 0x5000     0x5000     com.apple.driver.AppleUpstreamUserClient (3.5.13) <68 11 10 7 5 4 3 1>
  90    1 0xffffff7f81247000 0x11000    0x11000    com.apple.iokit.IOSerialFamily (10.0.7) <7 6 5 4 3 1>
  91    0 0xffffff7f81258000 0xa000     0xa000     com.apple.iokit.IOBluetoothSerialManager (4.2.0f6) <90 7 5 4 3 1>
  92    0 0xffffff7f80f55000 0x9000     0x9000     com.apple.iokit.IOUSBHIDDriver (650.4.4) <46 33 5 4 3 1>
  93    0 0xffffff7f810e5000 0x14000    0x14000    com.apple.iokit.IOSurface (91) <7 5 4 3 1>
  94    0 0xffffff7f80def000 0x7000     0x7000     com.apple.iokit.IOUserEthernet (1.0.0d1) <42 6 5 4 3 1>
  96    1 0xffffff7f814c1000 0x5000     0x5000     com.apple.kext.triggers (1.0) <7 6 5 4 3 1>
  97    0 0xffffff7f814c6000 0x9000     0x9000     com.apple.filesystems.autofs (3.0) <96 7 6 5 4 3 1>
  99    2 0xffffff7f80c35000 0x56000    0x56000    com.apple.filesystems.ntfs (3.11) <7 6 5 4 1>
And this is how my org.chameleon.Boot.plist:
       <key>InjectIntel-ig</key>
       <string>09006601</string>
       <string>No</string>
       <key>SMBIOS</key>
       <string>2</string>
       <key>Theme</key>
       <string>Blackosx_Default_II</string>
       <key>device-properties</key>
    <string>5e0000000100000001000000520000000100000002010c00d041030a000000000101060000027fff04002c0000004100410050004c002c00690067002d0070006c006100740066006f0072006d002d006900640000000800000003006601</string>
Thanks to that, I obtain this:
As you can see, it detects Intel HD4000 with 1024MB of VRAM, but it doesn't provide full accelerated graphics yet...
GraphicsEnabler=Yes -> It detects the Intel HD4000 at the boot, if not set, HD4000 does not exists.
InjectIntel-ig=09006601 -> It injects my device id (See screenshot):
Device ID:	0x0166
 Revision ID:	0x0009
Device-properties=... -> Hex string corresponding to 01660003 (If I use 01660009, it shows black screen instead of OS).
Any other idea? Thank you for your work and help.
u inject 2 ig-platform-id ?
and i see the appleintelhd4000 not loaded..
u must inject only one by key or by device properties
is only one.. u can use others.. if it works.. but only inject one in boot
u can't inject one by key and other by device properties
Now, typing kextstat in Terminal I'm getting that the following kexts are being loaded:
- AppleIntelHD4000Graphics
- AppleGraphicsPowerManagement
Using only HEX string -> Black screen
Using only IntelCapriFB -> Same situation as previous post: It detects HD4000 with 1024MB VRAM but not fully accelerated
I do not know what to do... This is very strange... Could you please post your chameleon plist and upload your kexts?
Thank you.
