Hi I can get to the choose language screen of the installer but USB kb and mouse don't work. I've tried different KB/Mice and USBFix flags etc?
Config:
Intel i3 540
gigabyte h55md2h
4gb corsair
SATA HDD
USB Mouse/Keyboard
USBBusFix only works in Chameleon. If you are using Clover, enable USB fixes in options menu.
I've booted multiple times with several flags USBBusFix, USBLegacyOff, busratio etc. But mouse/kb not working. Its strange that they work at the boot screen but afterwards they lose power. There's no light on either of the mice. Please help, I am stuck.
try to use from another mac os x version
iousbfamilly.kext
if u have a mac os x version it works
boot
-f -v
Hi guys, starting post stated:
"You need at least one free partition, use Disk Utility (in the Utilities menu) to erase it as Mac Os Extended (Journaled).
If you want to install the boot loader in this partition and you use MBR (not GUID, like if you already have Windows in the HD), it must be a primary (not extended/logical) partition".
I have MBR and a free primary partition of 50 GB for Mavericks. When I try to erase it to Mac OS Extended journaled using Disk Utility, it shows error saying that partition can't be modified because it's MBR.
Any suggestions plz..?
MD5 (OS X 10.9 Install USB.raw) = 6179a219e1bf7634fb321fabb8d3288d
- Copy the .raw file to an USB stick
For Windows
http://en.opensuse.org/SDB:Live_USB_stick#Download_ImageWriter
or
http://sourceforge.net/projects/win32diskimager/
If you have error during copy, eject and re-connect the pen drive. When Windows asks if you want to format it, cancel and run Image Writer again.
Ive successfully copied raw file to usb. Now what should i do?
iousbfamilly.kext
boot
-f -v
I tried the one from iAtkos L2 (Lion) but with it, booting fails altogether. It says some error like -> 'Unsupported with this version of library - IOUSBFamily Failed to load ...etc'
Thanks for any suggestions.
man a kext from lion ?
use the ones from ML pref from 10.8.5
Hi all.
Finally I was able to install Mavericks on my system y'day after trying a lot of different boot flags and patches in the included Clover bootloader. :D
However, I am still unable to boot from the hard disk. I have to use the same flags again and boot from the USB into the HDD. ANy help on this?
MD5 (OS X 10.9 Install USB.raw) = 3236daa1ae495a71b6c7c64f9322abc7
Which one is correct ?
I am getting the second one ie MD5: 6179a219e1bf7634fb321fabb8d3288d
(and SHA1: 6a2aa5186f3a46ff885af7391b6dde1c2aa19c41)
