djabbas Posted March 3, 2015 Posted March 3, 2015 I am confused. My hardware requires Chameleon bootloader as per tonycrapx forums. How do i use Chameleon instead of clover? well i tried using clover itself but the screes gets stuck at "system uptime [long numeric value]"
artur-pt Posted March 3, 2015 Posted March 3, 2015 hello http://Olarila.com/forum/viewtopic.php?f=28&t=4650 and stop talking about that " beast " thing or go out there here is Olarila.com no " beast".com if u start reading u will see the info in the forum good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
rphydra Posted March 13, 2015 Posted March 13, 2015 HP DV6 6033 Chipset HM65 Express I5 2410M HD3000 I installed Mavericks and everything was perfect only needed the flag cpus = 1 and all USB including USB3 worked To resolve the cpus=1 problem I used patch Lapic Kernel V7 (10.9) but UBS crashed Now everything works fine unless the USB Even using AppleUSBXHCI or GenericUSBXHCI I can not get USB Can someone help me Advance grateful
elSantosh Posted April 17, 2015 Posted April 17, 2015 I'm using Acer aspire 4738z ... It is continuously turning off at installer (after showing 16 min to complete the installation... ) ...please suggest solution.. Thank you
z3rito Posted April 21, 2015 Posted April 21, 2015 my system: proc: dual core e5200 motherboard: P43DE gpu: ati hd 7850 ram: 4 gb kingston SSD 120 Gb system: snow leopard 10.6.8 With Snow Leopard only works me with GraphicsEnabler = No because there is no support for my graphics I have tried every option (verbose, safe mode, without cache, whitout injected kexts ....) all options restarted my computer, without the installation menu appears. no error message, load drivers and reboot, any suggestion?
artur-pt Posted April 21, 2015 Posted April 21, 2015 hello try to boot with chameleon hit 1 to get chameleon screen is all in guide and should boot with GE=No good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
z3rito Posted April 21, 2015 Posted April 21, 2015 I tested with chameleon but the same result. when finished reading the files, restarts, fails to show anything
artur-pt Posted April 21, 2015 Posted April 21, 2015 hello with that info .. only guessing see ur bios sets and the smbios u use https://support.apple.com/en-us/HT201364 good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
z3rito Posted April 21, 2015 Posted April 21, 2015 the bios is fine, I started mac os x 10.6.8 smoothly, the problem is that after reading the files from usb not charge anything and directly restarts, show no mistake i tried several options, (-x -f -v GraphicsEnabler=No PCIRootUID=1 npci=0x2000) I've also tried the usb Yosemite and I happen the same
pernacabeluda Posted April 21, 2015 Posted April 21, 2015 Enable NX bit in BIOS setup http://Olarila.com/forum/viewtopic.php?f=2&t=1804 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
z3rito Posted April 21, 2015 Posted April 21, 2015 i change options in bios at cpu and it its working yeahh, thanks to all
blazure78 Posted April 22, 2015 Posted April 22, 2015 Hi guys! I got a similar problem too with reaching the installation menu. As I couldn't boot with Clover (didn't work don't ask me why, it just froze with a non-blinking underscore in the top left conrner, but whatever), I tried with Chameleon and it worked just fine, although i still cannot access the installation GUI and stuff. I'm stuck with a couple of errors such as "DSMOS has arrived" and a couple of other things (see the last 5-10 lines of the screenshot but please don't take in consideration the "unable to enumerate usb device" error-type that was really seldom). I'm aware it should be somewhat dealing with my GPU but, I have already checked out the manipulations in the first post (stuff like moving .kext into backup folder etc...) but it didn't work. Same thing with flags : i have already tested -v -x GraphicsEnabler=No KernelCache=No but it wasn't really effective huh. My PC is a PACKARD BELL BV IMEDIA J9610 with a PACKARD BELL BV GA-T671MG mobo (I know, that's antiquity stuff), with an Intel Core 2 Duo, and 3GB of RAM, my GPU -if you could ever call it that way- is an AMD ATi MSI Radeon R5450 in PCIExpress (and I had already turned it back to "PCI" in my BIOS). If someone could help pleaaaase x).
pernacabeluda Posted April 22, 2015 Posted April 22, 2015 You should run mv AMDRadeon* ATI* /kext_backup Then boot with -f (if using Chameleon). -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
blazure78 Posted April 22, 2015 Posted April 22, 2015 Still not working and I don't even have any AMDRadeon or ATI kext file in /S/L/E :\
pernacabeluda Posted April 22, 2015 Posted April 22, 2015 Try dart=0 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
blazure78 Posted April 22, 2015 Posted April 22, 2015 Not working either, but that was to be expected, my computer doesn't even handle virtualization x) I think it might be something dealing with SMC since it has prompted "ACPI_SMC_PatformPlugin::start - waitForService(resourceMatching(AppleIntelCPUPowerManagement) timed out". But I don't get what I'm suppose to do to prevent that :/
syahradzi Posted August 20, 2016 Posted August 20, 2016 Guys, i have problem with my installation. i already post my problem http://Olarila.com/forum/viewtopic.php?f=31&t=5788 , can anybody help me? don't intended to spam, but i really hope somebody can help me
kayoo7 Posted June 23, 2017 Posted June 23, 2017 Im hving problem with the installation 14 May 12 11:51:40 localhost OSInstaller[328]: Can not connect to /var/run/systemkeychaincheck.socket: No such file or directory 15 May 12 11:51:53 localhost OSInstaller[328]: PackageKit: ----- Begin Install ----- 16 May 12 11:52:34 localhost OSInstaller[328]: PackageKit: Got copier error 5 extracting to path /./system/Library/Framewroks/AppKit.framework/Versions/c/Resources/cs.lrpoj: Input/output error 17 May 12 11:54:18 localhost OSInstaller[328]: PackageKit: Install Failed: Error Domain=PKInstallErrorDomain Code=110 "An error occurred while extracting files from the package "Essentials.pkg"." UserInfo=0x7f8f65a850b0 {NSLocalizedDescription=An Error occurred while extracting files from the package "Essentials.pkg"., NSFilesPath=/Volumes/Untitled 1/.OSInstallSandbox-tmp/Root, NSURL=Essentials.pkg -- files:// localhost/System/Installation/Packages/OSInstall.mpkg, PKInstallPackageIdentifier=com.apple.pkg.Essentials, NSUnderlyingError=0x7f8f6759f520 "The file couldn't be opened because it isn't in the correct format."} { 18 May 12 11:54:19 localhost OSInstaller[328] Install failed: The installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance. 19 May 12 11:54:20 localhost OSInstaller[328]: No system on disk Untitled 1 to revert bless 20 May 12 11:54:20 localhost OSInstaller[328]: Unable to revert bless to target or imgsrc. It says like this and asks for restart i tried different HDD formatted to mac hfs+ but still no sucess Mobo: ASUS PQ5PL-AM Processor- Intel dual core Ram - 3 GB HDD- First Hitachi 320 GB Second - Seagate 120 GB
jh2017 Posted December 23, 2017 Posted December 23, 2017 Hi all. I'm on the verge of giving up when it comes to installing Mavericks on my main desktop (Inspiron 660 with a core i5 3340 and either a 750 Ti or an 8400 GS 1 GB or a GT 730 4 GB. None of the GPU's work with Mavericks aside from the 8400 since I had used the bootflags "-v dart=0 GraphicsEnabler=Yes nvda_drv=1" and that gave me full resolution at the installer and I installed and rebooted, only to be greeted with the error "IOBluetoothHCIController -- Missing Bluetooth Controller Transport!". I have tried countless boot flag combinations to try and fix this, yet it consistently is giving me this error. The reason I want to use Mavericks is I love the interface it has compared to the flat iOS design which the others after it have. If anyone could give me any pointers, I'd be grateful.. Oh, and if it helps: booting into safe mode doesn't work either. It simply reboots after getting past the IOBluetooth error.
