pernacabeluda Posted October 18, 2014 Posted October 18, 2014 I can't get it even to Clover (the USB sticks run fine on other PCs, but on this one it simply skips the drive..... Tried booting from a bootmanager on USB stick (PLOP) however I get an error that the drive doesn't contain a valid boot sector signature ( i've tried 10.9 image, 10.9.5 and 10.10) Try setting your BIOS to boot legacy instead of UEFI. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
vorloc Posted October 20, 2014 Posted October 20, 2014 Hi I also happen to get stuck while booting from chameleon, installed to the OS X partition. I get stuck at the iobluetoothhcicontroller completed like many around But i have tried everything given in order to get it to work, I moved the graphics kexts(even the bluetooth kexts) I tried the safe mode, i tried every switch for the boot ( -x -v -f GraphicsEnabler=No), i even tried changing the chameleon revision to an older one (rev 2266) Also installed the two FakeSMC and the null... kextsBut none of those seem to help . The problem here is, I CAN STILL boot from the installation USB and select the primary partition where OS X is installed. That way, it works! but I will have to have the USB with me at all times.! (Chameleon 2.2 rev 2266 is in the USB, that is why i tried a downgrade earlier in the OS) also even though i can boot up with the help of the USB, i still can't get my ethernet, bluetooth, wireless or audio working. I wanna know if I can somehow make the bootloader and it's config as it is in the USB installation media. Please help me out.. :/ I'm on an inspiron 15R (N5110) by Dell, it has a GT 525M video card, core i5 2.5GHz processor.
Zer01neDev Posted October 26, 2014 Posted October 26, 2014 i have a problem for installing http://Olarila.com/forum/viewtopic.php?f=9&t=4578 on my computer. it Freezing on Blutooth related device. iobluetoothhcicontroller completed Its show another line after said iTune/AppleStores, error blahblahblah a,d freeze.
Kuvar Posted October 27, 2014 Posted October 27, 2014 Can I install this on Original macbook pro 2008 model,If yes then As normal Procedure or something else . On macbookpro currently I have windows 7 installed fully,means no mac partition or boot camp etc. Thnx in advance Dell Vostro 3550, i5-2450M(2.50 GHz-Turbo Boost3.10 GHz) , RAM - 4 GB , Graphic - ATI Mobility Radeon HD 6630m 1GB(Switchable Graphics) , Chipset Intel PCH HM67, Yosmite 10.10/ Win 8.1 Pro x64/ Dualboot Chamelionwizard
artur-pt Posted October 27, 2014 Posted October 27, 2014 hello little google it help http://support.apple.com/kb/ht5842 PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
vojkan7 Posted November 1, 2014 Posted November 1, 2014 Hi ,I have problem please help me! When I boot wih usb os x Yosemite
pernacabeluda Posted November 1, 2014 Posted November 1, 2014 Hi, try to enable USB fixes in Clover options menu. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
erdem555 Posted December 13, 2014 Posted December 13, 2014 I completed install mavericks succsessfuly. It's working But didn't boot directly from HDD. I have to use usb stick for boot and select HDD boot option in the usb stick. But I want to boot directly from HDD. I don't want to use USB stick. How can I do?
artur-pt Posted December 13, 2014 Posted December 13, 2014 hello install a boot loader in the hd http://Olarila.com/forum/viewtopic.php?f=28&t=1716 good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
QueenOfHearts Posted December 17, 2014 Posted December 17, 2014 Hi, I have tried using the Olarila USB images for both, Yosemite and Mavericks but I get stuck before I reach the installer. I've followed all the bios settings recommended. The first problem that I had was getting stuck at PCI Configuration begin but I fixed that by booting with npcx=0x1000. Now I'm stuck at "Still waiting for Root device" Things I've tried and didn't work: -Using -gux_defer_usb2 and -gux_no_idle flags but it didn't work. -Enabling the USB Ownership in clover also did not work. -Using only one Memory Stick -Using maxmen=4096 Could anyone help me please? Attached is the error screen. My system is: Core i7-4790k Asus z97-A GTX 750 Ti 16gb RAM Thanks!
artur-pt Posted December 17, 2014 Posted December 17, 2014 hello see minimum options in ur bios http://Olarila.com/forum/viewtopic.php?f=28&t=4084 and that nvidia .. go give u problems good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
QueenOfHearts Posted December 17, 2014 Posted December 17, 2014 I already followed the settings provided in that post for bios but it's still the same error :/
artur-pt Posted December 17, 2014 Posted December 17, 2014 hello try remove from installer GenericUSBXHCI.kext u boot from clover so must access efi folder clover/kext good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
QueenOfHearts Posted December 19, 2014 Posted December 19, 2014 I'm trying to use Transmac to remove the kext from my USB but Transmac cannot see my USB. I tried it on two different USB and it still cannot see the Install USB in Windows 7. Any solutions to this? **EDIT** Okay I was able to get Transmac to read the install USB but I can't find the EFI/Clover folder This is the Olarila bootable USB image.
pernacabeluda Posted December 19, 2014 Posted December 19, 2014 Use the EFI shell. fs0: cd EFI\CLOVER\kexts\10.10 rm -r GenericUSBXHCI.kext -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
QueenOfHearts Posted December 19, 2014 Posted December 19, 2014 Thanks! I was able to remove the kext but still doesn't boot. I'm still getting stuck at the same screen :/
malik22 Posted December 24, 2014 Posted December 24, 2014 Hello guys im trying to install threw usb and get this error all the time.
pernacabeluda Posted December 25, 2014 Posted December 25, 2014 http://Olarila.com/forum/viewtopic.php?f=36&t=5006 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
omisayeee Posted January 17, 2015 Posted January 17, 2015 Hi all this tutorial's looks simple to me but when i tried it, is another thing all together. First : i downloaded image-writer and used it to copy OS x to my 62g flash. i tried to dual boot my hp pavilion dv6, selected my 62g flash i copied OS x ,press space bar in Clover and selected booting in single user mode... when the clover tried to proceed to installer i got this error nanoseconds 121212183311...... please if you wouldn't mind could you help me to get away from this challenge, this have kept me from learning how to develop OS App for two good months now.thank for your help.
J_Marley Posted February 18, 2015 Posted February 18, 2015 Okay, I apologize ahead of time as I'm betting this has been answered before, but I am a complete noob when it comes to anything hackintosh related. I have usually had either a Mac or a PC and this is my first system build trying to run both off the same machine. I am able to boot from the USB drive into Clover, but when I select to Boot the Mac OSX from the USB to install I get a terminal screen (or DOS like screen) that starts rattling through a bunch of language I don't understand, shows a few errors, and then I get a large white circle with a line through it in the middle of the page before the text on the screen all starts to merge together. I am completely lost as to what to do and how to install the OSX onto the secondary HDD I have installed in the computer. Current Computer specs from Everest: Intel® Core i7-4790K CPU @ 4.00GHz ASUS MAXIMUS VI HERO Motherboard NVIDIA GeForce GTX 750 Ti (2048 MB) WDC WD10EZEX-00BN5A0 (931 GB) x2 (one for Windows 8.1 and the other hopefully for OS X) 16GB DDR3 1600 (8GBx2)
