artur-pt Posted August 5, 2014 Posted August 5, 2014 hello give ur full hardware details .. u should use clover to try to boot.. and try 10.9.4 image.. if that graphics is the only present in system .. it don't work.. if u have also intel hd .. this one make ur efforts to work. good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
ycon Posted August 5, 2014 Posted August 5, 2014 I have a question (maybe a dumb one)- I have two hard drives- 120gd ssd for Windows 8.1 & 1tb mechanical for storage & Mac osx. Does the Mac OSX hard drive have to be a special format? The files/hard drive be accessible in Windows?
pernacabeluda Posted August 5, 2014 Posted August 5, 2014 OS X partition must be Mac Os Extended (Journaled) You need at least one free partition, use Disk Utility (in the Utilities menu) to erase it as Mac Os Extended (Journaled). The hard drive can be GPT (preferable) or MBR. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
praetorius Posted August 20, 2014 Posted August 20, 2014 Hi all. Managed to install 10.9 (using the link in the first post) and upgraded to 10.9.4. Graphics and Sound somehow i managed to fix. But when I installed Clover r2818 to the HDD, all the USB ports (for my keyboard and mouse) stopped working. Booting into HDD using Clover from the USB installer is ok. Anything I missed?
pernacabeluda Posted August 20, 2014 Posted August 20, 2014 Maybe they are connected to 3.0 ports? http://Olarila.com/forum/viewtopic.php?f=9&t=3388 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
mariarosaria Posted September 4, 2014 Posted September 4, 2014 I access the chat to download the images, but the links do not work. Can anyone help me?
artur-pt Posted September 4, 2014 Posted September 4, 2014 hello sure it work .. u are the first saying that .. if use mega .. use a compatible browser.. if use torrent .. just wait a little and should accelerate download speed good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
CaronteGF Posted September 26, 2014 Posted September 26, 2014 Can somebody tells me what´s the options in Chameleon at default in that USB Bootable?. I can boot up my OSX with it, but when i try install Chameleon pkg, i just get a kernel panic. My plan is install chameleon with the same options and cross my finguers. Thank you.
artur-pt Posted September 26, 2014 Posted September 26, 2014 hello nothing special -v GraphicsEnabler=No npci=0x2000 http://Olarila.com/forum/viewtopic.php?f=28&t=1716 good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
ivasija Posted September 27, 2014 Posted September 27, 2014 Hello guys i followed the instructions, bootloader works fine, it starts booting but after a while screen turns white and black i can't see anything it's like when phones screen is broken. can anyone help me?
artur-pt Posted September 27, 2014 Posted September 27, 2014 hello read 1º post ... install instructions are there good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
stratplayer Posted September 29, 2014 Posted September 29, 2014 I loaded this on my Dell XPS 9100 to a separate drive and aside from the lan (realtec rtl8168c) and the audio (realtec alc892) it works perfect I managed to load the kext for the lan and im all set there but for the life of me I cant get the audio to work, followed all the online instructions I could find and no luck (mulitibeast 6, etc) I end up with a intel hd audio device that is non functional I would really appreciate some help getting the audio to work and I also need help getting the boot loader from the usb to the hard drive too. thank you in advance
omisayeee Posted October 14, 2014 Posted October 14, 2014 Please Brothers i have downloaded OS X Mavericks 10.9,perfumed all the steps stipulated here but if i try to boot after choosing stall by USB it will hang; please what should i do? my system configuration is : OS:window 7 64bit Manufacturer: HP Pavillion DV6 graphics (GPU):intel graphics Adapter Bios: Hewllet-Packard Bio version : f.13 CPU: intel core i3 370m
omisayeee Posted October 14, 2014 Posted October 14, 2014 in continuation in what i posted earlier i found some text on my boot screen this is not the full text but some "local APIC error,ESR:64\n"@/sourceCAche/xnu/xnu-2422.1.72/osfmk/i386/lapic_native.c:774 Debugger called : Backtrace , Frame:Return Address: 0xfffff80be169ed0:0xfffff8010822f69 and other addresses then BSD process name courseponding to current thread: kernel-task boot args:-v npci=0x200 system uptime in nanoseconde:65648019 it HANGED Here.... please i need your help because i want to boot my pavillin dv6 into mac for me to run xtool.thanks
mew Posted October 15, 2014 Posted October 15, 2014 Any idea why the USB Pen won't boot on a HP DC7900? I've read some good feedback over at tonycrap....
pernacabeluda Posted October 15, 2014 Posted October 15, 2014 Use latest version which includes "lapic kernel patch" or add cpus=1 in boot-args. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
thane Posted October 18, 2014 Posted October 18, 2014 Installed nicely in a partition on my 2nd hdd. My 1st hdd has win7. BUT I need help because I just am not understanding something here. I am unable to get the bootloader to work when I install it on my partition on this 2nd hdd I named "MAC". I followed the guides to putting in the kexts in the 10.9 folder and what not, but my uefi motherboard doesn't allow me to boot from it. I have to access clover from my usb that has the os x install on it to get into the installed os x from the hdd. Any guidance in the right direction?
mew Posted October 18, 2014 Posted October 18, 2014 Use latest version which includes "lapic kernel patch" or add cpus=1 in boot-args. I can't get it even to Clover (the USB sticks run fine on other PCs, but on this one it simply skips the drive..... Tried booting from a bootmanager on USB stick (PLOP) however I get an error that the drive doesn't contain a valid boot sector signature ( i've tried 10.9 image, 10.9.5 and 10.10)
pernacabeluda Posted October 18, 2014 Posted October 18, 2014 Installed nicely in a partition on my 2nd hdd. My 1st hdd has win7. BUT I need help because I just am not understanding something here. I am unable to get the bootloader to work when I install it on my partition on this 2nd hdd I named "MAC". I followed the guides to putting in the kexts in the 10.9 folder and what not, but my uefi motherboard doesn't allow me to boot from it. I have to access clover from my usb that has the os x install on it to get into the installed os x from the hdd. Any guidance in the right direction? For UEFI boot you must install Clover in the EFI partition http://Olarila.com/forum/viewtopic.php?f=28&t=3405 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
