Did you erase EFI with diskutil eraseVolume?
It should not be auto mounted unless you did that or set MountEFI=true
http://clover-wiki.zetam.org/Configuration/RtVariables#MountEFI
Hi,
I try to install OS X into my laptop (Acer Aspire V3 772G)
I can boot from USB using legacy in bios settings and using Clover
I got some trouble before the installation but everything went fine after I replaced the Mach_Kernel with the patched kernel from here:
http://www.insanelymac.com/forum/files/file/173-109-kernel-xcpm-free/
The installation was a success but when I tried to boot OS X on the HDD, I got a infinite reboot loop in loading driver.
I tried many boot args such as "-v -f GraphicsEnabler=Yes PciRootUID=0", "-v -f GraphicsEnabler=No PciRootUID=0", etc (I searched as many as possible from the internet but it still got me into infinite reboot loop.)
After hours of trying, I try another method by setting my bios configuration to UEFI boot. I still couldn't boot from HDD but it shows something like this:
Loading Drivers......................................................................
Error reading driver XXXXXXXXXX ................................
(X is the kexts location)
I tried to boot in safe mode, without cache, verbose, etc but no success.
Any ideas?
(I can boot Windows 8.1 normally in Clover bootloader on my USB and even without USB using Windows Boot Manager when choosing UEFI mode in BIOS)
Thanks in advance!!
My computer specs:
Acer V3 772G
CPU: Intel i7-4702MQ 2.2 GHz
GPU: Nvidia GTX 760M (with Intel HD Graphics 4600)
120GB SSD and 1TB HDD (trying to install OS X in one of the three partitions)
Hi,
you have to replace mach_kernel in the installed system as well, and the first boot without caches (press space bar).
Hi,
Thank you for your reply : )
How do I replace mach_kernel in my installed system?
I try to use TranMac but I can't seem to write files into the installed partition.
Thanks in advance!
You can use the installer, open the terminal (utilities menu on the top) and copy it to the system partition
cp /mach_kernel /Volumes/"Mavericks volume name"/
If the Mavericks partition is not mounted, mount it using Disk Utility.
I finally managed to boot the HDD.
Thank you very much!
I am still in the process of searching the kexts for my drivers. Hopefully I can make my wifi working : )
Options menu in Clover or just type in Chameleon screen.
good to be part....will install and post challenges
All have a great evening
Intel® core i5 --3210M CPU @ 2.50GHZ
ASUSTeK COMPUTER INC K55A IVYBRIDGE
DDR3 4GIG MEMORY
Intel® HD Graphics 4000 1798MBytes
hi all,
i have windows 7,and i want to do i dual boot with hackintosh..mavericks..
pls i need a guide to do that
DDR3 4GIG MEMORY
no step by step to do this
u need a free partition to install mac os x or available space for that..
u need to read all info here in forum about u are trying to achieve..
pls do u mean,dual boot is impossible???
i will have time to read forum posts..
thanks
DDR3 4GIG MEMORY
If you have Windows installed in UEFI/GPT mode, I suggest you use Clover. Read the topic in my signature, but do NOT format the EFI partition since it already contains Windows boot files, just mount it. To resize Windows partition and create an empty one for OS X (if you don't have one) use the Windows Disk Management tool.
Hi to all,
i'm Alberto new on this forum...downloaded raw copy of mavericks and copyed with diskimager on 64GB pendrive...
After that i have booted on acer apire 5741 (proc: I3 Intel mainboard: new70 L11 video: Ati HD 5470)
but at boot remain black screen with blinking cursor... seems usb without boot..its possible?
is possible on my pc to install mavericks WITHOUT virtual box??
now i'm trying again...
tnx to all in advance
Alberto.
I'm wanting to run Windows 8.1 and Mac OSX Mavericks 10.9 on my Clevo W230SS/NP7338 laptop (on separate hard drives).
Is there anything special I need to know about this? I think I need the moded bios (PermaBios) but are there any other special points? Thanks
