u can boot from usb ?
if so.. maybe the pen is not good
I boot from usb. it shows "_" and it starts Windows.
I use San Disk Cruzer 8gb.
I try to download the version 10.9.2?
I use the same USB pen to install Ubuntu in another PC
Hi
I've managed to boot the install program after patching my mach_kernel, but two things are weird :
the progress bars are super sped up.. And whenever I want to type something, the key I press appears like 10 times on the screen. Which made it very hard to type stuff.
But anyway, after the install was done, I replaced the kernel with the patched one and booted (via clover on the USB stick).
It crashes and reboots. If I select "boot without caches" I get this :
http://i.imgur.com/mHjqE5j.jpg
I can type stuff, but it doesn't do anything.
Did I forget something ? I could try some boot options (like cpus=1 ,etc.) but I really can't type anything it's driving me crazy...
I get the feeling this is related to my intel HD 4400. I might find a solution, but nobody on the internet is saying anything about this weird keyboard issue.
Do you have a solution for me ? :(
Try moving video kexts from single user mode like pointed in post #1 and boot without caches.
The Intel are the ones you should move (do not delete as you will need them later).
If keyboard doesn't work you can move them using TransMac from a Windows machine.
I have successfully installed maverics on my dell inspiron 1500.
But when i restarted the system after finalising the installation, this is the screen i am getting.
http://imgur.com/YyAjDrT
What do you think is the problem?
Thank you.
I don't have windows on this machine, only Archlinux. Therefore I can't use TransMac and there doesn't seem to be an equivalent.
If I move the kext s (and remove the kernel cache) from the usb stick and then make a new install, will the newly installed OSX be affected as intended ?
EDIT : Alright, just tried it. removing the kexts from the usb stick doesn't prevent them from being installed.
So I can't use Transmac or use my keyboard easily. Any other tip ? :/
Apparently it's because of clover. Is it possible to boot the USB stick via chameleon instead of clover ?
EDIT2: Alright, it took me a long hour but I managed to move the kexts and remove the cache with this buggy keyboard. I will now try to install Chameleon, I hope it will fix my issue. I can boot hackintosh but everything is super sped up.
Linux can read and write HFS+ partitions if you have hfsprogs installed.
Anyway it doesn't have to be the same machine, it's an USB stick.
You can boot Chameleon by pressing 1, check the opening post.
Thank you.
Probably a video issue, try disabling graphics injection or move graphics kexts
http://Olarila.com/forum/viewtopic.php?f=27&t=1677
I just disabled the graphics injection when booting up but the result is the same.
Should I try reinstalling it without graphic injection?
Thank you.
EDIT: It looks like it is related to bluetooth card. I am not sure.
I ran it using single user and used the code below
fsck -fy
mount -uw /
mkdir /kext_backup
cd /System/Library/Extensions
mv AppleIntelHD* AppleIntelSNB* AppleIntelFramebuffer* AMDRadeon* ATI* GeForce* NVDA* /kext_backup
rm ../Caches/com.apple.kext.caches/Startup/kernelcache
reboot
Another edit: It stucks at resetting IOcatalogue :)
Your problem is video, bluetooth doesn't hang the system, it's just the last message usually shown before loading the graphics.
Intel HD 4400 needs some special settings, you will need that if you want QE/CI
It should have worked after removing the kexts, but you can also try the boot flags -v -x -f
Mavericks 10.9.2 Retail
When you ask for support, remember to tell the bootloader you use :)
Thank you :)
The flag thingy solved the problem and managed to login now :)
Looks good. Didnt recognise the wifi and when I move the safari, it flashes. Not a big deal but just wanted to mention it.
Other apps like notes do not flash when I move it :)
About the flashing, you will experience a lot of graphical problems because -x is safe mode, it doesn't load graphical kexts. You will have to search for how to set up Intel HD 4400 so that you can use its full power and boot fine without -x ;)
Hi all, first thank the support and shared information.
Well, a week ago I purchased a brand new surface pro 2 and the first thing I wanted to do is set you mavericks OS X, but after 8-10 attempts always stays on the screen attached to the post ... :oops::oops:
What am I doing wrong?
Any idea?
Thank you very much and good hack
Thks pernacabeluda (in spanish is "piernapeluda"... :lol::lol: ) but Im a very very noob & dont know how to make your advise...
If you have a tutorial of hackintosx, I would be be you eternally grateful
If you are using Clover, go into options menu and add "dart=0" in "boot args". If you are using Chameleon, just type "dart=0" and press enter.
Lots of thks pernacabeluda, the installer is working :D;)
It tell me that in 23 minutes are finishing... Im very nervous...
to have wifi, sound, rotation, What must I do?
Thks again you are the man!!!!
I had no luck. The installation was successfully but when reboot (with USB) from the partition with the OS X, the surface is stuck on a white screen with the apple in the middle ... I waited 30 minutes but no progress.I tried 5 times but not anything beyond this screen :(
Any solution ...
Thanks for your support and help, without you this would be impossible
