I see in your guide you need to input specific value for ryzen cpus. How do I adjust for ryzen 7 1700 ( 8 core)
Where do I edit the hexcode. I found proper tree  where you can edit EFI, but where is the line to adjust?
I can send more screenshots let me know.
AMD users need check some new things, check screenshot below
config.plist, kernel/patch
Hello i have problem, with my cpu information, make some changes but still same problem, my hackintosh can't see cpu information
Edited by nenada
what problem u have?
nvidia 610? change it
check here
I think I got it.   Download Xplist for windows and only change the replace value under kernel/patch for Item 1 to 3, from 06 to whatever your core number is.
u can use opencore configurator
