what bluetooth u have?
hi please help me on bluetooth working as my system showing below and in system preference turn on bluetooth not working.
Bluetooth Controller:
  Address: NULL
  State: Off
  Chipset: BCM_4350C2
  Discoverable: Off
  Firmware Version: v0 c0
  Product ID: 0x0001
  Supported Devices: 0x382039 < HFP AVRCP A2DP HID Braille AACP GATT Serial >
  Transport: UART
  Vendor ID: 0x004C (Apple)
below are kext files that i am using:
AirportBrcmFixup.kext Lilu.kext
AirportItlwm.kext LucyRTL8125Ethernet.kext
AppleALC.kext RealtekRTL8111.kext
AppleMCEReporterDisabler.kext RestrictEvents.kext
AtherosE2200Ethernet.kext USBInjectAll.kext
BlueToolFixup.kext VirtualSMC.kext
BrcmFirmwareData.kext WhateverGreen.kext
BrcmNonPatchRAM2.kext XHCI-unsupported.kext
IntelMausi.kext
On 5/17/2022 at 4:23 AM, Torsten Probst said:
Has anything been changed about Bluetooth with Mac OS 12.4? With Mac OS 12.3.1 Bluetooth worked and now with update to 12.4 Bluetooth does not work anymore. Thanks
Exact same problem here... Bluetooth used to work fine with 12.3.1, but now it's dead with 12.4.
Intel AC 3165 (WiFi and bluetooth)
WiFi is working fine
Had same problem. I'm using an Intel Wi-Fi AC 9462. On Monterey, there are some changes had to be done.
Make sure IntelBluetoothFirmware.kext v1.1.3 or newer is used.
Exclude the injection of IntelBluetoothInjector.kext for macOS Monterey from the Bootloader's config
Include BlueToolFixup.kext from acidanthera/BrcmPatchRAM (https://github.com/acidanthera/BrcmPatchRAM)
More info at:
https://openintelwireless.github.io/IntelBluetoothFirmware/FAQ.html#what-does-this-kext-do
Z490 UD AC
i9 10900KF Cofee Lake 10-Core
AMD Radeon RX 5500 XT 8Gb
Wi-Fi & Bluetooth working
Edited by yurimlima
