Hi,
I have a laptop hp dv6 6b41sf who worked pretty well under mountain lion, but after the last update, i have to re-patch aicpm.kext, so it boot again without nullcpu, but no more usb,exept with -x
The weird thing is if i boot with -f, it's slow to boot, but it's okay,usb back again,but non responding on my mouse clic, like system is at 100% or finder have to be reset (i succeed to only one time).
If i boot from an usb key with same chameleon as system has, and no spécial flags, it's ok too and work normally...
Maybe, it's because i don't patch the original 10.8.5 aicpm kext, but the patched kext from multishit, because i tied it before, so after i no longer had the original kext...
Maybe someone can give me the untouched kext so i patch it...?
I attached my dsds,ssdt,plist chameleon and aicpm.kext and fakesmc, maybe that can be useful.
If you've got an idea, and even if you don't, thank you!
portable.zip
so i delete some fake smc plugin, update my voodoo sound driver, repair permissions, and now i'm stuck at : iobluetoothhcicontroller missing bluetooth controller transport.
So actually i use -f to start and everything's ok, but i don't think it's the best way to do.
Problem solved!
I just downgrade the chameleon version, to 2.1 2043
That was that one i use from long time, few days ago i decided to change to the last one, and it seems that was a bad idea!
