Trackpad "click select" not working and wifi internet speed super slow.
Hi, I succesfully installed "High Sierra" on a Toshiba P755 and it's working fine I guess, the only issues I'm currently having is that I can't select anything with the touchpad, meaning the touchpad does work but I can't click on anything, the touchpad is a synaptics, I use a usb mouse because of that. The other problem I'm having is that wifi speed is super slow and would like to fix it somehow, the wifi card is an atheros ar9485 and I'm using IO80211Family.kext if that helps. Thank you very much.
this wifi is not good
the best is change this card. use broadcom
trackpad is just a correct kext. check what trackpad u have
Trackpad is a synaptics, I verified it and I've tried every kext that's supposed to work with my trackpad and clicking never works. Thank you for a fast reply, one last question regarding the wifi card, is it a problem with compatibility with macos? because I've installed linux and windows on this laptop and the wifi card works at top speed. Sorry, I'm very new to macos.
