Easy, Fast and Perfect Vanilla Hackintosh Installed on H110 and Z170 SkyLake - Clover or OpenCore bootloader
Donation with Stripe https://tinyurl.com/2ssnydn6
Donation with BuyMeaCoffee https://tinyurl.com/bvsbpf6e
-Posting full dump for one full ACPI solution. Check link bellow about Premium and Donators users.
https://www.olarila.com/topic/7717-important-premium-and-donators-users/
-Tutorial - https://tinyurl.com/y2dmt5af
-EFI Folders - https://tinyurl.com/5ddaryap
-OpenCore MOD EFI folders https://tinyurl.com/yvu7r52j
-USB Remap - https://tinyurl.com/2p88p2ff
Some Basic Information
-Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen
Bios/UEFI Configuration
-Sata = AHCI mode
-Secure Boot = Disable if need
-CSM = Disable with AMD cards
-If you have only IGPU use -igfxvesa bootarg for easy installation
