I am confused. Is it possible to make WiFi and Bluetooth working?
Hi Maldon,
My specs are AsRock B460m Pro4, Intel Core i3-10105f, RX550 4GB (works thanks to the patch you sent me before) and 16GB of RAM. I didn't have WiFi and Bluetooth in Windows working, only Ethernet. Today, I was viewing the system report of my hack and I found that it says this for the WiFi and Bluetooth sections. Also I have a bluetooth section in system preferences but I can't turn the bluetooth on and use it. Can I ask you what this means? Am I really able to get WiFI, Bluetooth, AirDrop etc. working or not?
system report.zip
Thanks! In the guide there are two kexts, itlwm.kext and AirportItlwm.kext On the guide it is not recommended to use both of them at the same time but I have seen a lot of people on videos on YouTube do this so what should I do?
Edited by FlashSn0w
Hi Maldon,
I tried with all possible kexts for Intel and Broadcom but still not working. Maybe I don't have a WiFi + Bluetooth card. One of my friends built the PC for me and I am not sure how to check if I have a card or not.
is a shot in the dark?
u need check what wifi/bt card u have before install kexts
Thanks! Am I able to do it with Hackintool or any other app directly on my Hack or do I need to create a live windows usb and check from there because now macOS is the only OS I have on my SSD?
Also I watched this video on YouTube:
and on the 4th section about WiFi&BT the person says that it is possible to have a WiFi/Bluetooth connectivity built into the motherboard. Maybe I have. I checked on google the specs of my AsRock B460M Pro4 https://www.asrock.com/MB/Intel/B460M Pro4/index.asp but I don't understand if I have WiFi&BT from the motherboard or not. Can you have a look and tell me if I really have WiFi&BT from the mobo or not? Also if I have, can I make it work in macOS?
Edited by FlashSn0w
adding links
